Old 13th Jun 2019, 4:50 pm   #1
record man
Default Bang & Olufsen Overture
Hi can anyone tell me, can i connect a B&O overture system to my 3300 type 1604 BeoCenter? If so how Many thanks
record man is offline
Old 14th Jun 2019, 8:23 am   #2
vinrads
Default Re: Bang & Olufsen Overture
Hi some pictures of the items and the sockets on the rear would be useful .Mick.
vinrads is offline
Old 14th Jun 2019, 9:27 am   #3
Beobloke
This should be achievable. The Ouverture has an AUX socket but I suspect this is only an input and not an output, although this would be worth checking. If it is only an input, the only way you could take an output to your Beocenter is through the Powerlink sockets, as they output a line-level signal for B&O active loudspeakers.
The problem here is that many B&O units stay muted if they do not detect any loudspeakers connected. If this is the case with the Ouverture, you would have to use one socket to take the output to your Beocenter (both Powerlink sockets carry both channels) and plug a DIN plug into the other socket with a 47kOhm resistor conncted between two pins (I cant remember which two offhand - I'd need to check!) which will fool the unit into thinking loudpeakers are connected, and it will un-mute.
Sounds Heavenly are a company who specialise in these sorts of cables for B&O, plus the muting adaptor, and Steve there is a very helpful chap who can advise further, so it would be worth contacting him (note, I have no connection with the company other than being a repeat satisfied customer!).
Frankly, though, it all sounds a bit complicated, as the other issue you will have is that you will have to set volume on the Ouverture every time you use it, as well as on the Beocenter, as the Powerlink output is volume controlled and not fixed. I assume it's CD replay you're looking for, in which case a nice Beogram CDX would be a lot easier.
Beobloke is offline
Old 14th Jun 2019, 10:35 pm   #4
record man
Many thanks all, i have been in contact with Steve from HS he is making a lead up for me so hopefully it will be ok.
