25th Dec 2016, 9:09 pm | #1 |
Pre-war television OB aerial
In "The London Television Service" .pdf document recently posted in another thread, I noticed this transmitting aerial. It relayed television OB signals back to AP on 64MHz, and here it is seen at Wimbledon.
We are told it is a "two-stack balanced series phase array" and is vertically polarised. Which are the active elements here? Is this some kind of slot aerial perhaps? Just wondering! Steve
https://www.radiocraft.co.uk |
25th Dec 2016, 9:17 pm | #2 |
Re: Pre-war television OB aerial
I suspect it's a version of the array of phased dipoles in front of a 'mesh' reflector: this was a style of antenna used quite a bit by the Germans during WWII for radar:
http://www.gyges.dk/luftwaffe_radart...ecognition.htm also known as a "billboard" antenna in the US: https://en.wikipedia.org/wiki/Reflective_array_antenna |
25th Dec 2016, 9:34 pm | #3 |
The strange thing in this example is that the aerial appears to have only one 'level', and where is the reflector? Could be a trick of the view though...?
Steve
26th Dec 2016, 2:09 pm | #4 |
It's tricky: even zooming-in and then electronically fiddling with the contrast then doing an 'edge-highlight' I can't actually see where the feeder is connected. The right-hand support pole has a cable/rope loosely wound several times around it midway up - could this be the feeder? Alas I can't see where it goes to higher up!
