25th Aug 2022, 2:10 pm | #1 |
Quad 33 attenuation of output to 303
I am trying to attenuate my 33 output as per Quad instructions and have fitted the 15k ohm resistors to the board as instructed and need to fit x 2 6.8k ohm resistors across the pins on the output socket - pins 1-2 and 2-3 to give a 12db drop. I am only doing this as noticed the volume is a bit sensitive compared to my other 33 both of which have had identical DADA upgrades which is odd in itself.
Space is a bit tight behind the amp boards and whilst i could squeeze in would it be easier to attach the resistors to flying leads which can then be soldered onto the pins of the output socket - page 5 in the link below. https://www.dadaelectronics.eu/uploa...ice-Manual.pdf Last edited by mikes08; 25th Aug 2022 at 2:17 pm. |
25th Aug 2022, 2:18 pm | #2 |
Re: Quad 33 attenuation of output to 303
25th Aug 2022, 2:52 pm | #3 |
To use fly leads could introduce hum, you are better off attaching them as Quad suggest.
Graham |
25th Aug 2022, 4:31 pm | #4 |
Nimble fingers and my tweezers then . Would i be ok to use 1/4 watt rather than half watt resistors?
25th Aug 2022, 4:53 pm | #5 |
As you can see space is tight. The output is just in front of the connector for the amp board.
26th Aug 2022, 10:53 am | #6 |
They would be fine, the only voltage and current passing through these resistors will the at line signal level so you could even go 1/8 watt.
Graham |
27th Aug 2022, 8:01 am | #7 |
Thanks Graham - that might make the job easier.
