Old 11th Sep 2018, 11:24 am   #1
Nymrod121
Nymrod121's Avatar
Default Avo Multiminor Mark 5
I'd originally posted one of these in the 'For Sale' section but being as there were no takers, I thought I'd tidy it up and press it into everyday service ... after all, it's so cute
By way of a 'rainy-day' exercise, I've just finished tidying up the instruction booklet. Here's a 'before' image along with a PDF version after scanning, Paintbrush-editing & general pithering/tidying up ...
This came out nicely using 210gsm white card on my laser printer. I'm happy to produce one-offs & send by post if anyone has need - just send me a PM with your address details https://www.vintage-radio.net/images...s/thumbsup.gif
Best wishes
Guy
Name:	AVO Minor booklet_090918001.jpg
ID:	169094   Click image for larger version
Name:	AVO Minor booklet_090918002.jpg
"What a depressingly stupid machine." [Marvin: HHGTTG]
Nymrod121 is offline
Old 11th Sep 2018, 11:44 am   #2
Nymrod121
Nymrod121's Avatar
Default Re: Avo Multiminor Mark 5
Here are the tidied-up scans if anyone wants to do a 'home-brew'
Best wishes
Guy
ID:	169097   Click image for larger version
ID:	169098   Click image for larger version
ID:	169099   Click image for larger version
Old 11th Sep 2018, 12:33 pm   #3
Superscope
Hi Guy,
Excellent Job.
I don't have a MultiMinor unfortunately.
I started tidying up some AVO Schematics a while back using Photoshop, but it is
an unbelievable amount of work to get a good Job.
I'm assuming you did your tidy up Digitally, or was there an element of Old School
Editing going on as well?
Ian
Superscope is offline
Old 11th Sep 2018, 12:51 pm   #4
John M0GLN
John M0GLN's Avatar
Agreed it is an excellent job, I do have one of these AVOs and have just downloaded your PDF version.
Thank you very much
John
John M0GLN is online now
Old 11th Sep 2018, 2:22 pm   #5
Nymrod121
Nymrod121's Avatar
Glad you like it ...
@Ian: I used a combination of Microsoft Picture Manager (cropping, rotating the scans to get them 'square') and Paint to edit out artifacts, paper rips/creases and the like.
@John: you're very welcome
Just for information:
The original 'mottled leatherette' (plastic) transit case is in very poor condition - the splitting rear flap hinge and sides having been repaired with black insulating tape has resulted in adhesive residue creeping all over the outside surface. Also, there is a cardboard tray that I presume once accommodated the test leads - this was crushed and torn - see the attached photos.
The test prods are OK now they've been straightened out but I suspect these are not original. The positive lead's right-angle wander plug was evidence of another 'temporary' repair as the outer cable insulation had come adrift from the plug's plastic strain-relief moulding at some point in its past; this had been resoldered then covered with red insulation tape. For the sake of tidiness, I replaced both of the meter-side connectors with the 'scrolled pin' type of wander plug.
Another 'minor' success (pun intended) arose from pure serendipity! A few days ago, I was ferreting through some of the other toot in my garage whe I came across a waist-belt-attached type of 'man bag' - this looked like it had potential to act as a replacement for the seriously tired leatherette case ... sure enough, it accommodates the test leads, meter and has other useful little pockets in it for (say) a spare 1.5v AA cell, the instruction booklet. Pics to follow separately.
Best wishes
Guy
ID:	169111   Click image for larger version
Old 11th Sep 2018, 2:43 pm   #6
Nymrod121
Nymrod121's Avatar
Here's the replacement case
ID:	169114   Click image for larger version
ID:	169115   Click image for larger version
ID:	169116   Click image for larger version
Old 11th Sep 2018, 3:49 pm   #7
Superscope
Hi Guy,
Have to say, it might not be the original, but I doubt
you would get a more practical Bag for the old MultiMinor
than you have there!
By the way, have you posted any AVO Serial Numbers you have
on the Multimeter Survey.
It's a Sticky Thread?
Ian
Old 11th Sep 2018, 6:41 pm   #8
Nymrod121
Nymrod121's Avatar
Hi Guy
I do have three 'conventional' (i.e. the heavyweight version) Avo's - I think I might have posted details of my first one some years ago * but will go through them all in due course ...
Best wishes
Guy
* (found it - it was post #840 in that 'sticky' thread - back in 2012 )
Old 11th Sep 2018, 6:42 pm   #9
The Philpott
The Philpott's Avatar
There's a certain irony to old instruments outlasting their cases, whilst there is a surplus of neat modern zip enclosures to be salvaged since their original occupants have become unreliable and joined the WEEE pile!
Thick film technology? A bit modern for me, Min.. Certainly looks lightweight though.
Dave
The Philpott is offline
Old 15th Sep 2018, 11:28 am   #10
avocollector
Hi Guy
many thanks for the posting - have several of these avominors.
avocollector is offline
Old 19th Sep 2018, 2:18 pm   #11
SteveCG
Many thanks for the user manual pdf.
SteveCG is offline
Old 1st Nov 2018, 12:25 am   #12
Refugee
Refugee's Avatar
The PDF is useful.
Refugee is offline
Old 1st Nov 2018, 6:34 pm   #13
Bazz4CQJ
Bazz4CQJ's Avatar
A few years ago I picked up two ex-services Mk5's for £1 each at a rally. One was perfect, the other had problems. I find it a very handy meter to have around; there are times when digital is just not the best way and the Mk8 I have stays 'in reserve'.
B
Bazz4CQJ is offline
