25th Jun 2018, 12:03 am | #1 |
LG-720 VHS Recorder.
Hi.
I own an L G-720, it works fairly well but using the aerial output lead I tried to tune it in to My Dynatron CTV 22/A. I could not get the tape that was playing to display. My question is if the SCART socket is being used does this stop the output to another set? At the time I was using my Sharp Duos LED set which is connected by means of a large box which all connections go through. I must add that this set it is connected by a ribbon cable. I have just noticed on the box it says its an AVC system for TV, Sharp Duos, LC -37and 1AD1E. I should mention that on the rear of the TV are just three inputs labelled 1/2/3,and no SCART or aerial inputs. Any advice welcomed. Regards, David. |
25th Jun 2018, 12:41 pm | #2 |
Re: LG-720 VHS Recorder.
Some VCR have settings to turn off the RF signal. I have never heard of one doing it automatically.
25th Jun 2018, 12:55 pm | #3 |
VCR's sometimes have a switch which feeds a test signal to the RF output. A vertical bar from what I remember. You then tune the TV around analogue channel 35 for the best display.
Some TV's had a dedicated VCR button on the tuner which changed the interlacing or something like that. I cannot see how a TV can have no aerial input socket unless it's actually a monitor.
25th Jun 2018, 1:01 pm | #4 |
I don't know anything about your particular machine but note that some later videos had the usual pair of Bellng-Lee, aerial in and out connections (i.e. "RF loopthrough") on the back panel, but had no RF modulator fitted, so can't display a picture on an old set with just an aerial socket on the back.
25th Jun 2018, 5:04 pm | #5 |
The Sharp AVC system is a way of getting rid of loads of cables dangling down when you hang it on the wall.
All the cables can be connected to the box, which should have the required connections. Then the cables to the TV come from the box. So yes it does not have any aerial leads, as they go to the box. You have to buy the connection cables (TV to box) from Sharp only. If you have not already got them. Apparently the longer length ones are very expensive. If the AVC box doesn't have a scart socket, you might be stuck. The modern set will certainly NOT have an analogue tuner to connect the VCR. Looking on the net I could only find Aquos - not "Duos". And the LC 37 is a Liquid Crystal set NOT an LED TV. |
26th Jun 2018, 1:51 am | #6 |
If the set is in fact an LC-37AD1E, it is quite vintage and the box will certainly have one or more SCART sockets.
26th Jun 2018, 1:18 pm | #7 |
Bear in mind that some of these later VHS units had user-settable UHF modulator output between ch 21 and 68, not just channels 29-39 like the early ones.
If you can't pick it up, it may be clashing with a DTT multiplex.
Regards, Ben. |
26th Jun 2018, 8:53 pm | #8 |
Hi.
Yes the AVC box has 3 SCART sockets and appears to work fine. The OSD lists TV/DTV/Input 1/Input2/Input/3/Input4/PC. What I am doing is using the RF output lead from the L.G.Video and tuning my Dynatron CTV 22/A to receive the picture/display, but my question is if I leave the SCART still connected as normal, does this stop the RF output giving a signal to the set I wish to connect it with. I have just looked and I'm not able to see any screw to adjust the RF output. |
26th Jun 2018, 9:50 pm | #9 |
Can you not consult the user manual to find out which analogue channels the device is capable of outputting and how to select which one is used?
26th Jun 2018, 11:51 pm | #10 |
27th Jun 2018, 12:22 am | #11 |
Hi Graham point well taken.
I got the player second hand from eBay £90.00. I saw it working and am very satisfied with it, but it did not come with a user/instruction book /guide. The frustrating thing is I thought that with the Dynatron having a 625 UHF input that I just needed to tune into the tape being played. Regards, David. |
27th Jun 2018, 12:44 am | #12 |
I have never heard of a video that cuts the RF when using the scart AV output.
No adj. screw as the RF output is set electronically. Please check the model number again. If it is an LG LV-720, try this: 1) Press POWER on the front of VCR to switch it to standby. 2). Press and HOLD the PROG "^" or "V" on the front of VCR for more than 4 seconds. 3) This should turn on the RF Modulator and set it to CH22.
Regards, Ben. |
17th Dec 2018, 10:33 pm | #13 |
further information as follows.I purchased a RF modulator with this I managed to connect up the VCR and tune the dynatron in so that problems now solved.I now need to replace the main cable as one of the 3 has a break in it the plug on it looks similar to a 5 pin din plug but smaller.I have noticed this plug is almost the same as the plugs fitted to computer keyboards but these have six pins .I require one that has 5 pins what are they called so I can try to purchase one or has anyone got a sharp avs I could purchase one regards David
18th Dec 2018, 3:05 am | #14 |
I'm not entirely sure from your post (a picture says more than a thousand words sometimes), but you may be describing an S-video connector.
18th Dec 2018, 3:24 am | #15 |
Remember the old type like audio 5 pin DIN plugs? Well it's like that only smaller and looks, when you view it looking at the pins, like it has a bar in its centre. By the way I found this thread and it was Grubhead who pointed out I has mistakenly posted it was LED. I now realise it's LCD. It certainly had a good picture when the cable was good, but it got damaged by the cat playing with cables, so the cover is missing
19th Dec 2018, 11:35 pm | #16 |
Well it looks like persistant searching has at last paid off. I found a similar model sharp LC -TV for sale I contacted the seller who said he had a spare cable and was willing to sell it to me. Hopefully this will resolve things and make it work again.
