16th Sep 2016, 8:15 pm | #1 |
Bush TV22 Picture Fault
I am about to embark on help a good friend of mine in solving a picture fault on this Bush TV22, the problem being with a good signal from an arora standards convertor the picture is generally weak and has bars across the screen, it's as if there is sound on picture, however on saying this can't seem to find the problem.
Any Idea? Regards Ken |
16th Sep 2016, 9:49 pm | #2 |
Re: Bush TV22 Picture Fault
Check all the HT voltages, this could be a smoothing cap problem putting "hum" into the video circuits.
16th Sep 2016, 10:16 pm | #3 |
If you haven't already, change all the wax paper capacitors - in any case. What's the state of the valves? all they all known good ones? Has the set previously been restored or is it pretty much original, ie potentially full of faulty components, bad connections etc. There's just so much to go out if the set has not been restored. I always used to to go 'all through' a newly acquired vintage TV, never looking for individual faults until all the basics were done.
16th Sep 2016, 10:32 pm | #4 |
Check the 16uF cap C25 especially if the verticals are distorted. This cap decouples the line oscillator plus the RF chassis.
Keith |
17th Sep 2016, 4:44 pm | #5 |
Thanks everyone, and ok Keith all noted on that c25 cap
Will let you know how I progress Ken |
20th Sep 2016, 2:57 pm | #6 |
Hi Keith
You were quite right about the 16uf, it measured only 9uf, somewhat different from what it is supposed to be, replacing this has improved the sets performance but still got to check out C25 which decouples the screen of V7 an ECL80 Ken |
20th Sep 2016, 4:21 pm | #7 |
That cap decoupling pin 7 of the ECL80 will be a wax paper type and will almost certainly be leaky. The screen grid is fed via a 1.5Meg resistor so the leaky cap will pull the screen grid voltage down affecting the sync separator performance.
Have you replaced the other wax paper caps as they will almost certainly be leaky after 60 odd years. Keith |
26th Sep 2016, 7:36 pm | #8 |
Hi Keith and everyone
latest update on the progress, changed 16uf electrolytic and the decoupling cap on V7, found a few others that were up the creak in and around the sync circuit but I also suspect that metrosill so going to put a request on the want section, otherwise the picture and sound seem fine Best wishes Ken |
26th Sep 2016, 9:57 pm | #9 |
Have you changed C18 the reservoir capacitor for the A1 supply for which the metrosil is the rectifier. This is a very high impedance circuit and any leakage through C18 will cause the A1 supply to drop. Even measuring it with a DVM can load the supply. The Bush service manual says to use an electrostatic voltmeter to measure the voltage.
From memory C18 is hidden under the tagboard close to the metrosil. Keith |
27th Sep 2016, 11:21 am | #10 |
Hi Keith
Not changed C18 but will do so on your advice thank you for that, will update as I progress Ken |
