Old 14th Nov 2017, 5:02 pm   #1
Radio Tech
Radio Tech's Avatar
Default Murphy A122
So here is another project I have landed myself to do, and on initial inspection the dial cord broken and off, all the rubber covered wiring needs replacement, one or two dial lamps u/s, electrolytic capacitors look as if they have been replaced at some stage as one marked radio spares, the other too small for the chassis mount clip, all wax caps (axial ones) will need replacement and most likely leaking electrically like the electrolytic ones, one knob not matching the other three, rectifier looks as if it has had a hard time as covering scorched but all the valves test ok and clearing the usual amount of dust revealed that the paint work on the chassis is like it was in 1944. Here are some pictures of the chassis.
More to follow
Ken
ID:	152254   Click image for larger version
ID:	152255   Click image for larger version
ID:	152256   Click image for larger version
Radio Tech is offline
Old 14th Nov 2017, 5:20 pm   #2
ukcol
ukcol's Avatar
Default Re: Murphy A122
Hi Ken.
What is the red metalised valve fitted in the rectifier position? Not the UU6 that is usually fitted.
ukcol is offline
Old 14th Nov 2017, 5:27 pm   #3
http://www.r-type.org/exhib/aad0243.htm
Old 14th Nov 2017, 5:38 pm   #4
ukcol
ukcol's Avatar
Thanks Lawrence, ' never seen a metalised UU6.
ukcol is offline
Old 14th Nov 2017, 5:52 pm   #5
A set well worth getting going by repair, rather than restoration keeping the history of its life. IMHO the cabinet is worth getting looking brand new, no stain, let the wood shine through, Murphy did make a very good cabinet with style.
They where very modern in design and you may get away with it in a contemporary room, call it the iWood.
Old 14th Nov 2017, 6:33 pm   #6
Boater Sam
There were quite a few UU series valves that were metallised, and later ones weren't, perhaps they found out that it was unnecessary and fell of anyway.
Looked pretty though.
Boater Sam is online now
Old 14th Nov 2017, 6:57 pm   #7
Andrewausfa
Andrewausfa's Avatar
Hi Ken,
Deja vu. That looks almost in exactly the same state as one I had a few years back.
PS. I'm sure Mike Lewis had some A122 etc knobs in his black knob box at the last Harpenden.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 14th Nov 2017, 7:00 pm   #8
Radio Tech
Radio Tech's Avatar
Thanks for the input fellow members, it will be a little while before it is looking like it should, and yes, Murphy strange as it is did make very good cabinets, pressing on, more to follow.
Best wishes
Ken
Old 14th Nov 2017, 7:30 pm   #9
David G4EBT
David G4EBT's Avatar
The cabinets weren't actually designed or made by Murphy, but by R.D. Mills and Eden Minns.
In 1930 Gordon Russell – a furniture designer whose business was suffering due to the depression - received a call from Frank Murphy who said “ I am an engineer making radio sets and for some time have admired your furniture – would you like to design and make cabinets for me?” Over the next ten years Dick Russell and Eden Minns designed over 70 radio sets, gramophones and televisions. By 1939 Gordon Russell’s employed close on 1,000 employees, the majority engaged in Murphy cabinet production in a newly built factory at Park Royal, London.
A lovely example of a Murphy baffle set here:
1930 – 1940:
http://www.gordonrusselldesignmuseum.org/six-decades/
Gordon Russell also led the team that designed and arranged the manufacture of 'CC41' utility furniture by firms all over Britain during and after the war years, much of which was of course urgently needed due to people being bombed out of house and home and having to set up home again.
The Gordon Russell Design Museum, opened in 2008, is located at Broadway Worcester, in the Cotswolds - where the 'Arts & Crafts' movement originated:
http://www.gordonrusselldesignmuseum...ordon-russell/
I recently mentioned an excellent free 85-page 'e-book' about the history of Murphy cabinet design from 1930 - 1950 and the role of R.D. Russell and Eden Minns - lots of excellent pictures from glass plates rescued from a skip at the Murphy factory in the nick of time. The Author of the book worked at Murphy and was involved in cabinet design with Russel, & Minns. Worth giving the link again:
http://www.*************************..._1930-1950.pdf
I can understand why so many enthuse about Murphy sets of that golden era.
Hope that's of interest.
In many ways, its rather a shame that it often tends only to be the electronics that arouses interest in radio restorations - cabinetry being considered by many as something of a chore.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 14th Nov 2017, 8:49 pm   #10
It is essential for household harmony (a wayleave may be granted for a specially good job too) and you get satisfaction from a whole job well done.
Old 15th Nov 2017, 1:09 am   #11
Refugee
Refugee's Avatar
I also have an A122 but mine is the M version with a slightly different speaker fret.
If you need to compare any measurements it is fully working.
Refugee is offline
Old 16th Nov 2017, 11:53 am   #12
Radio Tech
Radio Tech's Avatar
Many thanks for that very interesting article on the cabinet David, I never thought that a different company designed those cabinets for Murphy Radio. Just a little update on the progress so far, I have done quite a bit of the wiring replacement as and where I find the rubber insulation has gone hard and naturally falls of the conductor, most of it is around the mains transformer and power sections. Have now started on the capacitors. More to follow....
Ken
Old 18th Nov 2017, 5:20 pm   #13
Radio Tech
Radio Tech's Avatar
Hello Fellow Enthusiast's
Here is an update on the restoration of this set, during the process of renewing some of the wiring I found the screened lead that ran from the volume control to the wafer switch had perished, oh dear, so it was a case of finding something suitable to do the job and as you see from the picture of the wafer assy it required a great deal of quiet and patients to get in there with a soldering iron! phew! But however, I did manage it and then got on with replacing the smoothing caps, I replace one with a dual 16uF and the other with a 10uF, just got to find a large rubber bung to blank the hole off. So have a look at these pictures.
Best wishes
Ken
ID:	152455   Click image for larger version
Name:	New Components 1.jpg
ID:	152456   Click image for larger version
Name:	Bottom Components.jpg
ID:	152457   Click image for larger version
Name:	Wafer Switch.jpg
Old 21st Nov 2017, 9:12 pm   #14
Radio Tech
Radio Tech's Avatar
Hi Folks
Few of the last pictures of this set, now complete with exception to one control knob, I think Rob who sent the set down to me will be pleased it has now been restored and I will leave it up to you for your thoughts on the look of it now.
Best wishes
Ken
ID:	152668   Click image for larger version
ID:	152669   Click image for larger version
ID:	152670   Click image for larger version
Old 21st Nov 2017, 9:40 pm   #15
David Simpson
Well Ken, you've really had your hands full with your A122. Certainly a great improvement in the end.
As you may have seen, I've just been involved with a A122 "repair services wanted" thread from Aberdeen. Thankfully Richard's A122 wasn't in too bad a nick. Fair bit of elbow grease was needed cleaning & polishing the cabinet, and thankfully the circuitry didn't need too much repair work.
That range of Mazda valved sets have lovely balanced multi-turn tuning, and the audio valves - HL41DD & Pen45 put lovely sound into the speaker with excellent tone & volume control.
If any one else gets the offer of owning or working on one - jump at the chance. One slight drawback is the sheer size & weight.
Regards, David
David Simpson is offline
Old 21st Nov 2017, 11:59 pm   #16
For the "bung" why not just use the dead large can electrolytic that was replaced by a modern one?
Herald1360 is offline
Old 22nd Nov 2017, 12:46 am   #17
dave walsh
Thanks for all this usefull 122 info from everyone including Ken, David-Cabinet Design/ overall History and David S [but I don't think they are that big really]. Iv'e got two good ones, must check them out]. It's not hard to see why people get drawn into "Murphy Madness". There is an engaging combination of both the Britsh character and a willingness to embrace "Modernism" from the thirties onwards. Frank M's story would make a good film regardless of the product. Like J L Baird, he was forced out of his own Company
Dave W
dave walsh is offline
Old 22nd Nov 2017, 12:17 pm   #18
David Simpson
Yes Dave, get your two out onto your bench(if its big enough) & give them an electronic cuddle. That range of sloping back Murphy's are a joy to behold. I had a U128, which has very similar circuitry, until quite recently, when I donated it to our local museum. As it had a close link to the late Bill Smith - of "Bill Smith Chronicles" & " Radio Bygones" fame, and who lived nearby. I've still got my Reece-Mace Type N Marine Rx, which again has the same Mazda valve line up. The quality of Murphy's cabinet veneering & the choice of Mazda based circuitry is the most superior of all the wooden domestic sets I've worked on. Good on yer - Ken & Dave - keep on giving Murphy's loads of tlc.
Regards, David
Old 24th Nov 2017, 6:05 pm   #19
robin coleman
A wonderful set, I have one. Love the baffle sets. I am missing a few of the sets after the A122. Keep up the good work. The Murphy designs were ahead of their time.
Regards, Robin.
robin coleman is offline
Old 25th Nov 2017, 12:22 pm   #20
Tractorfan
Tractorfan's Avatar
Smile Re: Murphy A122
One of the first sets I was given as a kid (and didn't butcher) was one of these. It had lived in a joiner's shop for years and had its fair share of wood shavings and dead spiders within.
Knowing nothing back then of leaky caps, perished wiring, etc., I just switched it on and waited. And waited. After checking that the valves had warmed up, I realised that I hadn't fitted an aerial.
Eight feet of flex out of the bedroom later, I was rewarded by absolute loads of stations and spent hours slowly trawling the short wave band. I still have some scraps of recordings I made off air.
I eventually gave it to an aunt and never saw it again. However, I have now got two more which work well, but need the usual work doing. Goodness knows when I'll ever get round to it, and I imagine I will eventually let them go to a good home.
They are indeed lovely sets.
Cheers, Pete.
Name:	A pair of Murphys.jpg
Tractorfan is offline
