Old 24th Oct 2017, 11:37 am   #1
Henenen
Default Panasonic NV-FS88 Super VHS VCR - Flicks between Colour / Black & White
I have a Panasonic NV-FS88 which seems to be working fine other than it will randomly swap between Colour and Black & White output for several minutes at a time during playback.
Is this an easy fix?
I've tried different scart cables, get same fault so I know it's not that.
Henenen is offline
Old 24th Oct 2017, 12:04 pm   #2
Vintage Engr
Default Re: Panasonic NV-FS88 Super VHS VCR - Flicks between Colour / Black & White
I assume that the monochrome playback is clean? If it isn't it might be worth doing a head/tape path clean.
Do you have a service manual for this?
If you do, it might be worth checking the power rail around the video processing areas. Many Panasonic & other makes of VCR's etc from this period suffer from failiure of small electrolytic capacitors, going high ESR.
Looking at the relevant power rails with an oscilloscope usually reveals lack of decoupling, so the chroma signal gets lost to the power supply.
There could of course be many other reasons, so a manual is really a necessity.
David.
Vintage Engr is offline
Old 24th Oct 2017, 1:30 pm   #3
HamishBoxer
HamishBoxer's Avatar
Always check/change secondary psu caps for oddball faults before moving on.I have had a few on NatPan.
HamishBoxer is offline
Old 24th Oct 2017, 2:53 pm   #4
Henenen
The playback in B&W is clean, yes, and the tape path has been cleaned.
I don't have a service manual though. Was hoping it was a simple/common problem.
Henenen is offline
Old 24th Oct 2017, 7:18 pm   #5
John123
Most likely to be a capacitor issue which tends to plague this generation of machines as they're quite long in the tooth, by now. Usually most of the trouble is with the S-VHS side of things.
Try leaving a tape to play from start to finish as it might need a little 'waking up' especially if it hasn't been used in a good while. Also, check the 'Normal/ S-Video Out' switch on the back is not stuck half way or anything. It should be set to 'Normal' unless you are using S-Video over SCART.
John123 is online now
Old 25th Oct 2017, 12:27 pm   #6
Henenen
Funnily enough, John123, I ran it all day yesterday, and this morning, and it has actually been fine.
Up until that point it hadn't been used for years, so maybe the capacitors did just need 'warming up'.
Henenen is offline
Old 25th Oct 2017, 3:39 pm   #7
Welsh Anorak
Welsh Anorak's Avatar
Hi
I think you're right - the SMD electrolytics used in this machine are notorious, and not an easy fix. Keep it warm and dry and hopefully the fault won't come back.
Glyn
Welsh Anorak is offline
Old 25th Oct 2017, 6:29 pm   #8
John123
Sounds like it just needed some encouragement! Yes it's not uncommon for old capacitors to need a little time to 're-form'. As above, look after it and it should be OK for now.
Old 25th Oct 2017, 7:26 pm   #9
Vintage Engr
Yes, these capacitors tend to work again when gently warmed up.
Believe it or not, the same series of SMD caps were used in both domestic & broadcast equipment.
I have a drawer full of 'new' ones, I sometimes changed up to 40 on one single board. Not a nice job, but it generally did the trick.
David.
