Old 30th May 2020, 1:23 am   #1
joebog1
Default NOS capacitors
So the capacitors that I ordered a couple of months ago have arrived. PIO military types.
They were made around 1964 ( a few different dates). So I have measured them and they would seem perfect for my audiophoolery . Circuit requirements call for .5Uf coupling capacitors, so I will parallel two of these up to give me something very close to that value.
There are only two capacitors in the audio path, those being the couplers from the phase splitter to the driver valves fot the push/pull output quad.
I did notice that they have quite high inductance, and with a bit of thought I will parallel them in opposite directions to try and counter that somewhat. Initial tests show I can reduce that inductance to almost zero. So I have a couple of questions!. Does my audiophoolery thoughts on reducing that inductance make sense, or am I just being silly?.
Note the glass end seals on these caps !!
Some pictures to show what quality meant back in the 1960's
Joe
ID:	207191   Click image for larger version
ID:	207192   Click image for larger version
ID:	207193   Click image for larger version
ID:	207194   Click image for larger version
joebog1 is offline
Old 30th May 2020, 10:57 am   #2
duncanlowe
Default Re: NOS capacitors
22 MegaFarads. Wow!
duncanlowe is offline
Old 30th May 2020, 11:02 am   #3
M0FYA Andy
I think MFD is a fairly standard abbreviation for microfarads?
Andy
M0FYA Andy is online now
Old 30th May 2020, 11:07 am   #4
Amraduk
Hello Duncan,
Originally Posted by duncanlowe View Post
22 MegaFarads. Wow!
They are 0.22uF, not 22uF!
Regards,
Dave.
Amraduk is offline
Old 30th May 2020, 11:15 am   #5
duncanlowe
Have to admit I missed the decimal point. And I realised it couldn't really be M for Mega, but u is what I'd expect for micro (properly greek mu), and m for milli. Always made me laugh when Tandy advertised radios with 250MW output power using a PP3.
Old 30th May 2020, 11:16 am   #6
ionburn
ionburn's Avatar
Maybe the lack of inductance one way is from you effectively putting together like a non-inductive wirewound resistor?
ionburn is offline
Old 30th May 2020, 11:53 am   #7
GrimJosef
Originally Posted by joebog1 View Post
... I did notice that they have quite high inductance, and with a bit of thought I will parallel them in opposite directions to try and counter that somewhat. Initial tests show I can reduce that inductance to almost zero ...
I'm a bit surprised at that. Inductance arises from the energy stored in a magnetic field. To reduce it we need to arrange that opposing fields from different sources (the two different capacitors) overlap in space and so cancel one another. Where, in space, do you think the field for a single capacitor might be strongest, and is it practical to arrange overlap between those regions for two capacitors ?
Cheers,
GJ
http://www.ampregen.com
GrimJosef is online now
Old 30th May 2020, 2:36 pm   #8
DMcMahon
DMcMahon's Avatar
Do not know what type of dielectric medium these capacitors are. If a paper type dielectric than due to age they potentially could have become leaky.
If they are going to see DC voltage like a valve anode to grid coupling capacitor then to be on the safe side, would be worthwhile checking them out for leakage (if you have not already done this of course).
DMcMahon is offline
Old 30th May 2020, 2:56 pm   #9
dazzlevision
So, the capacitors that I ordered a couple of months ago have arrived. PIO military types.
Joe
PIO = Paper (dielectric) In Oil
dazzlevision is offline
Old 30th May 2020, 4:49 pm   #10
DMcMahon
DMcMahon's Avatar
Aha, I wondered what PIO was
DMcMahon is offline
Old 30th May 2020, 7:40 pm   #11
factory
They look like a hermetically sealed metal cased capacitor with plastic cover.
More info here: https://www.parttarget.com/5910-00-8...E-41DE5303C690
They sound better than the plastic PIO Sprague HV capacitors I keep finding in HP oscilloscopes, they definitely leak (their contents everywhere).
factory is online now
Old 30th May 2020, 8:42 pm   #12
Yes!
Old 30th May 2020, 11:45 pm   #13
Herald1360
Herald1360's Avatar
Joe
Not entirely. Two inductors in parallel without any mutual coupling will behave like resistors in parallel so if they're identical the circuit inductance will be around half that of one on its own.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
