20th Jul 2008, 8:52 am | #1 |
Repairing push button switches
Hi. I have a Blaupunkt Virginia 2430 am/fm radio (1956) that has a button for am ferroceptor/external aerial. The button will not hold down in place when pressed, so the internal ferrite aerial is not in circuit. Anyone else experienced this problem ? The spring (visible from the underside of the switch bank) seems in reasonable condition.
Many thanks Mike |
29th Jul 2008, 8:45 am | #2 |
Re: Repairing push button switches
I have no idea how thiese work , but presumably a catch must be prought into play by the spring ? maybe it needs lube
29th Jul 2008, 7:40 pm | #3 |
Hi. Many thanks for your reply. The button will not keep down once pressed, thats why I thought the spring might be faulty.
Regards Mike |
29th Jul 2008, 10:53 pm | #4 |
its just possible that something needs lubrication as it may be jammed . the spring wont do the job if so . Its possible the spring is stretched
30th Jul 2008, 7:54 am | #5 |
Mike
If this is a "push on, push off" type of button, there will be some sort of catch to retain it in the "on" position; this is usually a small pivoted lever with a slot in it, and a hairpin spring to keep it against a peg on the sliding part of the switch. Is such a thing visible?
Mike. |
