Old 28th Aug 2019, 7:25 pm   #1
Triple M
Default Yaesu FRDX400
My FRDX400 decided to burn out its mains transformer last week taking out the house mains trip at the same time.
Looking at the transformer it looks to be pretty well cooked with melted varnish that has seeped out and onto the chassis.
Is there any one that has a spare (perhaps from a broken for parts) receiver? or possibly someone that can rewind/rebuild the existing unit?
Any help gratefully received as I don't want to scrap what is a fine and (up to the meltdown!)clean radio for the sake of a transformer.
I will be replacing most of the capacitors as suggested elsewhere, but can't see any other obvious reasons for the breakdown.
PS I'm also looking for a 6M converter board for the unit as well assuming it can be fixed..
Thanks in advance
Glenn (G0HPS)
Triple M is offline
Old 28th Aug 2019, 9:27 pm   #2
g4aaw pete
g4aaw pete's Avatar
Default Re: Yaesu FRDX400
Hello Glenn
I think if you put this post in the 'wanted' section of the forum, one of our resident transformer rewind experts may be able to help.
Wonder what the HT & LT current requirements are? You may be able to use a fairly standard transformer from another redundant piece of equipment.
Regards
Pete
g4aaw pete is offline
Old 30th Aug 2019, 12:20 pm   #3
G8BBZ
G8BBZ's Avatar
Hi Glenn,
I had the same problem some years ago. Spent ages looking for a replacement transformer without success. Transformer failure seems to be fairly common with the Yaesu 400 family. Eventually I built an outboard power supply and put it in the cabinet I built to hold a speaker for the receiver and was quite satisfied with the result. Still a decent receiver in my view.
Good luck
Peter G8BBZ
G8BBZ is offline
Old 30th Aug 2019, 5:33 pm   #4
dodgy-dxer
dodgy-dxer's Avatar
Repeating my previous advice on Facebook to contact Ed Dinning (Dining?) on this Forum for a rewind
Fred
dodgy-dxer is offline
Old 31st Aug 2019, 3:46 pm   #5
Andrew B
Andrew B's Avatar
Same here, I mentioned Ed on Facebook as well, you'll find him on "services offered"
worried about the electrons entering the circuit and the smoke leaving
Andrew
Andrew B is offline
Old 31st Aug 2019, 5:15 pm   #6
Andrew B
Andrew B's Avatar
Originally Posted by g4aaw pete View Post
Hello Glenn
It's a monstrous iron lump, rated about 500W or so, multiple taps for 800v, 300v, 150v, + others.
Andrew
Andrew B is offline
Old 31st Aug 2019, 5:48 pm   #7
g4aaw pete
g4aaw pete's Avatar
Originally Posted by Andrew B View Post
Hello Glenn
Curiosity got the better of me, so I looked at the manual.
Output from the transformer appears to be:
6.3v (about 3A)
13v ( supplying a few transistors)
200v .
The spec. states 50w power consumption from AC mains.
On that basis, the current requirement doesn't seem particularly huge.
Regards
Pete
Old 31st Aug 2019, 8:11 pm   #8
Restoration73
Restoration73's Avatar
Yes it's only a receiver, not the FTDX400/500 transmitter which does have a large transformer, so HT 200V @ 100mA should suffice.
Restoration73 is offline
Old 1st Sep 2019, 11:43 am   #9
dodgy-dxer
dodgy-dxer's Avatar
Correct
If he had asked for the FTdx401 mains transformer I may have been able to help him
73 Fred
G4BWP
Old 1st Sep 2019, 1:11 pm   #10
Andrew B
Andrew B's Avatar
ooopps, should have read the question properly re FRDX not FTDX
Andrew
Andrew B is offline
Old 1st Sep 2019, 4:25 pm   #11
m0cemdave
I have used a couple of these receivers and noticed that the mains transformers ran extremely hot. I wonder if they were originally designed, and "value engineered" for 60 Hz mains supplies?
m0cemdave is offline
Old 1st Sep 2019, 4:37 pm   #12
G6Tanuki
G6Tanuki's Avatar
Could be - though remember that in Japan part of the country has historically been 50Hz and another part 60Hz so I guess they'd have designed to tolerate the frequency-spread.
Also looking at the schematic the primary is two windings rated for 117V which are wired in series to get 234V-compatibility. Here, the mains is never below 245V and during the day can go up to 252V - which would significantly stress a designed-for-234V setup.
G6Tanuki is offline
