30th Sep 2012, 8:11 pm | #21 |
Re: Aerial for apartment (indoors)
Yep that's what I've done MW is good at night. Bit ropey during the day, SW Very few stations. LW only radio 4.
But if your a purist stop reading I've connect a small fm radio so I can get the standard stations via gram input and works a treat. Thanks for all your help, can you tell this is my first vintage set |
1st Oct 2012, 10:27 am | #22 |
A trick I used years ago was to hang a length of wire from the curtain rail with a coil of enameled copper wire wound around an old ferrite rod connected the bottom of it and with the other end of the coil fed into the aerial socket - a very crude base loaded aerial. This was utterly random but it made a significant improvement on medium wave. No doubt with a bit of tuning and experimentation with the size of the coil I could have made it work even better.
You'd have to make a bigger coil for long wave, of course or, if you were being really fastidious, by experimentation you could tap the coil with a switch. It's surprising that your reception of R4 long wave is so poor as Droitwich is only 15 miles down the road. |
5th Sep 2014, 8:58 am | #23 | |
These days I simply listen to my MW or SW radio stations on my Xiaomi Mi3 mobile phone using internet chrome where they come live on some internet links. |
