28th Aug 2014, 8:55 pm | #1 |
Please help identify Radiospares tools
Well, sort of 'tools'... this is a set of what appear to be flexible plastic feeler gauges, in a small Radiospares packet. They're unmarked, but there are three each of four thicknesses: Green (0.15mm), Red (0.28mm), Yellow (0.40mm) and Grey (0.55mm). The nearest Imperial equivalents would be 6 thou., 11 thou., 16 thou and 22 thou.
Does anyone recognise them or remember using them, and what were they for? Phil
28th Aug 2014, 9:05 pm | #2 |
Re: Please help identify Radiospares tools
Setting Strowger relays?
28th Aug 2014, 9:12 pm | #3 |
These are still available from, Farnell, CPC etc. They're used where a non-conductive/non- scratching feeler gauge is required.
Never used on Strowger equipment to the best of my knowledge. Angled gauges marked in mils (thous) were used there and they had a hole which the relay's residual screw fitted through.
29th Aug 2014, 6:19 pm | #4 |
My experience of Radiospares goes back to the mid-1960s when it was feasible for anyone of the necessary mindset to know the catalogue almost by heart and I don't remember these. That would suggest either that my memory is defective - but marble loss usually affects recent rather than ancient memories - or that they are from an earlier time as the typeface on the case would appear to confirm.
In those days Radiospares were still mainly involved in the radio & TV repair trade and often much looked down on by "professional" customers making it unlikely that an item for telephone relays would have been part of their range. Equally sadly, I can still remember Radiospares' London address in full. PMM |
29th Aug 2014, 11:58 pm | #5 |
Thanks for everyone's thoughts. I hadn't considered the need for non-conductive feeler gauges, but that sounds the most likely suggestion. Radiospares sold a comprehensive range of octal and 11-pin relays, so maybe these feelers were designed for adjusting the contacts on these. The colour coding does suggest that they were designed for a specific purpose. They might even be used for setting the contact gaps on Avometer leaf switches...
I agree Peter, the "RADIOSPARES" suggests the 1950s but I think I've seen this style on later items as well.
30th Aug 2014, 12:42 am | #6 |
Do they come in sets of 3?
Could they be for centering loudspeaker cones? |
30th Aug 2014, 8:04 am | #7 |
They are indeed in sets of 3. That's an interesting suggestion! They are the right sort of shape and thickness too.
1st Sep 2014, 8:16 pm | #8 |
Hi They were used for replacing or centering loudspeaker cones. I remember using them way back in the mid 50s. John.
1st Sep 2014, 10:17 pm | #9 |
That's most helpful, John. Many thanks.
As my question has been answered, Mods, this thread may be closed. Thank you.
