16th Oct 2018, 12:24 am | #1 |
British Physical Labs RM175-LZ II Megohmmeter
This tester from circa 1966 is yet another old school beast that has been surpassed for ease of use by many a modern hand-held 'megger', but still retains lab grade functions like setting any DC test voltage from 0 to 1kV, and a sub microamp meter that goes down to 6pA FS to allow measurement to 5 tera-ohm (which beats the pants off my 2 giga-ohm megger).
It uses a nice resonant reactor voltage regulator to provide 1% internal voltage rails for 180-250Vac mains. The leakage current measurement is done with an EF37A differential amplifier. Just another British Physical Labs instrument that I had waiting for some tlc (https://www.vintage-radio.net/forum/...d.php?t=149963). Ciao, Tim |
16th Oct 2018, 9:22 am | #2 |
Re: British Physical Labs RM175-LZ II Megohmmeter
Around 20 years ago, before a refit, we had around six Farnell TSV30T from the early '60s. The Volts and Amps meters on these were made by British Physical Laboratories, Radlett. Maybe they had a commercial arm to produce these items.
Neil
16th Oct 2018, 10:46 am | #3 |
I wonder why the EF37As weren't ME1400s?
16th Oct 2018, 11:09 am | #4 |
Argh, link to restoration doc - forgot to add that in the first post:
https://www.dalmura.com.au/static/BP...175-LZ%202.pdf |
16th Oct 2018, 4:46 pm | #5 |
Ah, yes BPL mirror scale moving coil meters. We used then exclusively at Reyrolle in a whole range of test sets with 50uA to 1mA sensitivities.
Quite a few were converted to "poor mans home made Avos" Ed |
16th Oct 2018, 5:02 pm | #6 |
I thought the ME1400 was identical to an EF37A, just run at a different heater voltage?
A Mullard con-trick. Andy |
