Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Repair and Restoration Services Wanted
Repair and Restoration Services Wanted If you need someone to repair or restore equipment for you please post your request here.
Old 28th Aug 2018, 1:46 pm   #1
JimmySB
Default Aristo-craft Train Engineer Transmitter CRE 55470
As the title suggests I am after the repair of an Aristo-craft Train Engineer Transmitter CRE 55470. Don't know much about Rx/Tx, however it is a 27Mhz system that controls train power supplies, it's broken into 10 frequencies and then 10m channels.
I bought the system second hand, and the faulty handset came as a free addition, I was informed that it would not "bind", this hand set has an off switch and auto shuts off, but after one week not switched off the new batteries were completely flat.
Can anybody provide assistance or direct me to assistance.
Many thanks Jim B
JimmySB is offline
Old 4th Sep 2018, 10:25 am   #2
JimmySB
Default Re: Aristo-craft Train Engineer Transmitter CRE 55470
Sadly it seems that nobody here is able to assist me with my repair, if anybody could provide details of a commercial venture that maybe able to assist I would very grateful.
Many thanks.
Keep the rubber side down
biker quote
Jimmy B
JimmySB is offline
Old 4th Sep 2018, 1:14 pm   #3
It may simply be something no-one else on here has ever come across. I don't know whether you're talking about a piece of equipment for use on full-size trains, or on models. The word 'engineer' associated with anything railway either sounds American or refers to Mr Brunel
Some photos might help stir some thoughts.
Radio Wrangler is offline
Old 4th Sep 2018, 1:49 pm   #4
AC/HL
AC/HL's Avatar
It is for model railways, there is at least one for sale on eBay at the moment, but I'd think that any member in a position to help would have responded. You may need to contact the distributor, if there is one in the UK.
Bill, BVWS member
AC/HL is offline
Old 5th Sep 2018, 12:30 pm   #5
JimmySB
David, many thanks for the steer (pun intended), I will look to post photos.
Bill, many thanks, I do keep an eye on ebay, and the last one I saw was in USA. Sadly these are no longer sold and the manufacture has gone as well, so no source to go back to, hence my use of this site hoping somebody could provide some direction. I would have hoped that somebody with knowledge of the workings, maintenance and repair of 27 Mhz transmitters could have helped
biker quote
Jimmy B
JimmySB is offline
Old 6th Sep 2018, 3:44 pm   #6
David Simpson
Jimmy, Pictures and a copy of the circuit diagram would help. 27MHz is at the top end of the HF(Short Wave) Band. Some amateur radio guys might be familiar with your circuitry. I know nothing about model railways, but you mentioned 10 frequencies & then 10 channels, so some sort of FSK or complicated modulation might be involved. Us lot, being mainly "vintage", are more likely to be familiar with just CW, AM or SSB, or FM transmitting circuitry.
Is there not a Model Railway Forum out there on the internet ? Or a club somewhere near you ?
Regards, David.
David Simpson is online now
Old 7th Sep 2018, 4:59 pm   #7
JimmySB
David, it was a model railway forum that pointed me this way, I don't have a circuit diagram though I will enquire, however this link should take you to the manual:
Aristo_Walk Around Train Engineer Manual
Photos of the item:
Hope this helps, thanks
ID:	168906   Click image for larger version
ID:	168907   Click image for larger version
biker quote
Jimmy B
JimmySB is offline
Old 8th Sep 2018, 4:03 am   #8
Terry_VK5TM
You could try this forum:
https://www.gscalecentral.net/
There is quite a lot about the Aristo Craft Train Engineer if you search through the forums, including manuals, repair info etc.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 8th Sep 2018, 10:20 am   #9
JimmySB
Terry, many thanks, however that is the forum that suggested this forum!!
biker quote
Jimmy B
JimmySB is offline
Old 8th Sep 2018, 7:19 pm   #10
Sound Man
Sound Man's Avatar
Contact details for Aristo Craft is available on the following document - http://gscale.net/images/manuals/Ari...hz2_Manual.pdf
Sound Man is offline
Old 9th Sep 2018, 2:34 am   #11
Terry_VK5TM
OK, full circle it is
So can I assume you've also tried the Aristo Craft forum? http://www.aristocraftforum.com/index.php
Re the document in David's post - Crest Electronics closed down in 2016.
Terry VK5TM
Old 9th Sep 2018, 2:59 am   #12
Restoration73
Restoration73's Avatar
The 27MHz technology is all similar. I don't think 75MHz is a UK approved frequency.
These might be worth trying, they are located in the south west;
http://www.rchobbyestore.co.uk/repair-service-i44
Restoration73 is offline
Old 11th Sep 2018, 7:51 am   #13
JimmySB
Thanks guys, a couple of more leads to follow. I am sure I am not the only person who needs one of these items repaired, I will keep the forum updated for any future needs.
biker quote
Jimmy B
JimmySB is offline
Old 12th Sep 2018, 7:45 am   #14
JimmySB
I have looked at the forum and identified a source in the USA for repair, awaiting response, I have also contacted RC Hobby Store, and had a positive response from Graham, so things are looking up.
biker quote
Jimmy B
JimmySB is offline
