Old 19th Nov 2019, 5:31 pm   #1
vampyretim
Default Sony TC-540 low recorded volume
Hello,
I'm working on a Sony TC-540 reel to reel recorder. I've replaced the leaking motor caps and the unserviceable level input pots. I have a problem that on both left and right channels however loudly you set the input to be recorded you get a very weak and muddy recording on the tape.
Has anyone had any experience with this reel to reel?
Many thanks.
vampyretim is offline
Old 19th Nov 2019, 6:02 pm   #2
ms660
ms660's Avatar
Default Re: Sony TC-540 low recorded volume
Used to service these back in the 1970's, most problems were either switch related or tape path related, eg: dirty switch contacts, dirty heads, they must be spotless...difficult to tell for sure without a magnifying inspection mirror, poor tape to head contact due to other reasons eg: pressure pad problems also goes without saying that the tape needs the correct bias and that the head mustn't be worn out.
Lawrence.
ms660 is offline
Old 25th Nov 2019, 8:40 pm   #3
vampyretim
Lawrence.
Thanks Lawrence, I've had another look at it today and it seems that after a good clean of all the switches the only problem I've now got is that one channel is pretty muddy, a bit like a speaker with a downed tweeter. The other channel works as it should. I'm going to get a scope on it tomorrow and see what's going on.
Thanks again.
Old 26th Nov 2019, 6:42 pm   #4
vampyretim
I've had a weird thing happen as I was trying to fault find this today. Every time that I plugged another item into it that was hooked up to the mains (external amp. Sig gen) it drew a massive current from the power supply and took out its 1.5A fuse. I even got a shock when I tried to inject a signal. It's like there's a potential difference with whatever electronic item that you connect to it. It's acting like a short in the tape machines power supply I even had it when only the earth conductor of my sig gen was connected to the chassis of the tape machine.
Any idea what's going on?
