24th Jun 2016, 10:28 pm | #1 |
Bush MB 60 Mains Plug Repair
Has anyone attempted to repair a mains plug for the valved Bush MB 60 ? is it possible to open it up to fit a new lead ? as this is a spare i can afford to experiment ! any suggestions ?
regards, Tim. |
25th Jun 2016, 1:13 am | #2 |
Re: Bush MB 60 Mains Plug Repair
I'd say you've got nothing to lose by trying. See if you can get the ribbed top off in one piece with a slitting disc in a Dremel or a fine hacksaw. It can always be rebuilt with glue and filler once a new lead is fitted.
25th Jun 2016, 1:58 am | #3 |
I have an MB60 lead that has an elderly repair. Looks like the top has been sliced off with a craft knife, the flex re-soldered and fixed back together with four small wood screws. I'm away from home at the moment, but I'll post some photos when I get back on Tuesday.
Regards, Tony
G8KBG - BVWS Member - BATC Member |
25th Jun 2016, 8:52 am | #4 |
Herald 360, yes I've nothing to lose just wondering whether to cut the top off or the two pronged part from the top . Will wait for Tony to post his pictures. I thought of maybe making some sort of mould out of resin but I think that would be a job for a pro. Will post some pictures when I've sliced off the top. Tim
30th Jun 2016, 3:07 pm | #5 |
Apologies for the delay in posting the photos. I hope they help.
Regards, Tony
30th Jun 2016, 8:08 pm | #6 |
Thanks Tony ,it gives me some idea whereabouts i need to slice the top off ,cant say its the most elegant repair iv`e seen but i suppose its functional, regards, Tim.
30th Jun 2016, 8:25 pm | #7 |
No, not elegant at all. Not helped by the fact there are a couple of bits broken off either, but it is surprisingly solid when all screwed together.
30th Jun 2016, 8:58 pm | #8 |
Flippineck ! Death trap alert !
I've often wondered if it would possible to mould or 3D print a suitable plug; cant be that difficult ? I've also often wondered how many MB60s were ever used with batteries; possibly not that many. Its a shame that the number of genuine mains leads in captivity is (it would appear) greatly exceed by the number of MB60s. |
30th Jun 2016, 10:15 pm | #9 |
Not really a death trap- unless you undo the screws whilst it's live. Not pretty, and could do with the soldering tidying up and some careful moulding with a bit of slow epoxy resin, but I've seen worse 13A plugs than that !
3D printing or even machining from a solid bar could be used to produce a better result, but would involve a fair bit of time and enthusiasm.
30th Jun 2016, 10:40 pm | #10 |
I changed the mains lead on my plug with minimal chopping about.
I went in from the old mains lead with a dremmel type tool until I found the soldered joins. A new lead was soldered in and then araldite the car body filler used hold it in place and fill the gaps David
http://www.youtube.com/ My Nixie Clocks |
