13th Dec 2021, 12:41 am | #1 |
Help Identifying A Pye Set
Hi all, I picked up a set last Friday just on a whim and because it was cheap. Originally my thoughts were to turn it into spares but when I actually picked it up I looked at it and am tempted to give it a chance. The only problem is... I can't identify it!
There is no model number on the rear panel and the only mark I can see is the Pye sunburst logo on top. I know its shabby but that shouldn't be a bad thing to start with. Any clues would be gratefully received! |
13th Dec 2021, 8:36 am | #2 |
Re: Help Identifying A Pye Set
Its very similar to the PYE 835 but a better identification may be achieved with some pictures of the Chassis and the valve line up.
https://www.radiomuseum.org/r/pye_835.html Cheers Mike T
13th Dec 2021, 8:45 am | #3 |
Pye were awful at not identifying their sets.
13th Dec 2021, 12:29 pm | #4 |
It could also be a Pye 834. Here's the restoration thread relating to mine. I hope you have better luck with the tuning flywheel and mains transformer. If both are knackered like mine then I hope you enjoy a challenge! https://www.vintage-radio.net/forum/...d.php?t=179688 Cheers, Jerry
13th Dec 2021, 12:54 pm | #5 | |
Cheers Mike T
13th Dec 2021, 1:02 pm | #6 |
quite often pye scribbled the model number in pencil either under the cabinet or just inside
Kevin |
13th Dec 2021, 10:41 pm | #7 |
13th Dec 2021, 10:43 pm | #8 |
Thanks Gentlemen. I will get it out of the car and take it to bits. That will give me the look inside. The only reason I havent yet is the bench is covered in bits of other radio.
Many thanks once again. |
15th Dec 2021, 10:18 pm | #9 |
I can certainly relate to that!!!
Mark Edgeworth ____________________________________________ BVWS Member |
