Old 11th Jul 2020, 9:39 pm   #1
Station X
Station X's Avatar
Default Heater-cathode leakage when hot.
There've been a few threads on this subject in the past.
Recently I been testing the valves in my Trio 9R-59DS, some of which must be approaching 50 years old and have seen a lot of use. I also tested pulls from the set and spares for it.
6BE6's and 6BA6's seemed to be particularly bad in this respect and I obtained the following readings on an AVO CT160.
6BE6 200k and 300k
6BA6 230k, 230k and 600k.
By comparison NOS examples typically showed readings in excess of 20M although one example measured 10M.
Graham. Forum Moderator
Station X is offline
Old 11th Jul 2020, 9:45 pm   #2
Default Re: Heater-cathode leakage when hot.
I have never seen it as a datasheet value, does it matter in the real world?
Old 12th Jul 2020, 3:25 am   #3
retailer
After finishing a Fender amp copy build for my son I grabbed a handfull of used untested 12AX7's plugged them in and it all seemed good - the amp worked fine, however as the amp warmed up and he continued to play and experiment with the tone controls etc a hum developed which got louder by the minute, the first pre-amp valve had heater to cathode leakage when hot, according to my Taylor valve tester - over 2 meg when cold and less than 10k when hot.
retailer is offline
Old 12th Jul 2020, 10:54 am   #4
Station X
Station X's Avatar
I've never seen a figure quoted either. The advice in the CT160 manual is.
It is not possible to state a rejection figure in Mohm for a valve under test, for such a fault will be of considerable importance in some circuits, whilst in a few cases its presence has no consequence at all. The instrument is capable of giving the insulation between cathode and heater, and the acceptance or rejection of the valve can only be determined when the operator has details of the circuit in which the valve is to be used. In those cases where details are not known, it is always better to reject a valve having an insulation resistance of less than 10Mohm. It will be appreciated that there are many circuits in which an appreciable potential exists between heater and cathode, dc amplifiers etc., and the presence of heater to cathode insulation breakdown, even of the order of many Mohm, can often give rise to quite serious trouble. Heater to cathode insulation breakdown either permanent or intermittent can also give rise to noise in valve amplifier circuits.
Old 14th Jul 2020, 6:08 am   #5
trobbins
trobbins's Avatar
Some valves have a minimum limit test applied during production, especially the more highly specified valves like CV4024, 5687WA and rectifier 6X4WA. Sometimes it is implicitly measured by way of a hum/noise compliance test as per a 7025.
trobbins is offline
Old 14th Jul 2020, 10:24 am   #6
David Simpson
Graham, from the 1960's, I've stuck to the CT160's Manual's "10Mohm". Often one sees a rise from 1Meg to 5Meg, then creep to 10Meg, or a similar reverse drop. Once this fannying about starts - just bin it. Unless, of course, folk want to keep a valve for collection/display purposes.
Regards, David
David Simpson is offline
Old 14th Jul 2020, 10:27 am   #7
turretslug
turretslug's Avatar
ISTR that pretty much every one of the small number of metal 6J5s here that I checked showed H-K leakage between hundreds of kilohms to many megohms when cold- my thinking was that as they were only likely to be used as HFO or BFO in the AR88 here where cathode is connected directly to chassis in both cases, then it was pretty much inconsequential.
Cathode-follower use, especially with a high H-K DC potential difference and high value cathode resistor, would be a different matter. Also applications like PSU regulators and DC-coupled amps.
turretslug is offline
