Old 30th Jun 2020, 12:01 pm   #1
Peter73
Default Beethoven 4 valve set, Identified as a model 99.
Does anyone have any info' on this radio, I have drawn a blank so far.
The valve lineup is: PENA4, VP4B, 345V and an unidentified four pin rectifier.
I'm guessing that it dates from the late 1920's
ID:	209881   Click image for larger version
ID:	209882   Click image for larger version
ID:	209883   Click image for larger version
ID:	209884   Click image for larger version
Peter73 is offline
Old 30th Jun 2020, 12:04 pm   #2
Station X
Station X's Avatar
Default Re: Beethoven 4 valve set
Beethoven radios often had a model/serial number stamped on the rear of the chassis where the aerial sockets are.
Graham. Forum Moderator
Station X is online now
Old 30th Jun 2020, 12:49 pm   #3
Peter73
Unfortunately there is nothing stamped on the chassis anywhere.
There is evidence of an ID plate having been removed just below a Mullard copyright plate on the inside of the cabinet.
Peter73 is offline
Old 30th Jun 2020, 12:55 pm   #4
Station X
Station X's Avatar
Interesting frame aerial.
I assume this is a mains powered TRF set?
Old 30th Jun 2020, 12:59 pm   #5
Peter73
Yes it would appear to be.
Peter73 is offline
Old 30th Jun 2020, 3:08 pm   #6
PJL
That sort of dial would place it around 1933/34.
PJL is offline
Old 30th Jun 2020, 4:36 pm   #7
Station X
Station X's Avatar
Yes, not likely to be earlier than about 1933. Droitwich opened in 1934, but the frequency would have been announced in advance and manufacturers would have labelled their dials accordingly.
At some time Beethoven switched from TRF to superhets. My own model 64 is a TRF and I believe "Radio Radio" shows a slightly later numbered model which was a superhet. The model shown would probably have had a lower model number than that.
EDIT. I just had a look at the circuit for model 77 which is a mains superhet.
Old 30th Jun 2020, 4:57 pm   #8
Gridiron
Only similar sets listed in the Mullard Valve Replacement guide are:
AC78 : VP4 or VP4A (7 pin), 354V, PENA4, IW3
AC99 : VP4 (7 pin), 354V, PENA4, IW4/350
283 : AC/VP1, 354V, PENA4 (7 pin), IW4/350
If model 77 is the same as AC77 this is must be a superhet as has a FC4 in the list of valves.
Mike.
Gridiron is offline
Old 30th Jun 2020, 5:25 pm   #9
Station X
Station X's Avatar
Mike.
Radio Museum have a picture of a 77, but none of an AC77. I don't know whether they're the same set.
Old 1st Jul 2020, 10:42 am   #10
Peter73
Thanks for your input gentlemen, I will keep looking.
Peter73 is offline
Old 8th Jul 2020, 2:55 pm   #11
Peter73
Apologies gents, I should have gone to Specsavers ! How I missed the numbers on the Gram socket panel I really don't know.
99/4333 does this help?
Peter73 is offline
Old 8th Jul 2020, 3:01 pm   #12
Station X
Station X's Avatar
Beethoven model 99 serial No. 4333.
That probably doesn't get you any further than a positive ID though.
Old 8th Jul 2020, 4:08 pm   #13
ms660
ms660's Avatar
Something odd to me about this receiver, cabinet front doesn't look right, another receiver planted in the cabinet? Different chassis but similar tuning scale and loudspeaker bars in this one:
https://www.radiomuseum.org/r/beetho...per_minor.html
Lawrence.
ms660 is offline
Old 8th Jul 2020, 5:37 pm   #14
PJL
Here is another one: https://www.the-saleroom.com/en-gb/a...8-abeb0126de64
PJL is offline
Old 8th Jul 2020, 5:45 pm   #15
ms660
ms660's Avatar
That's my theory out the window then.
Lawrence.
ms660 is offline
Old 8th Jul 2020, 5:45 pm   #16
Station X
Station X's Avatar
Looks like the mains transformer in the OP's set is a replacement.
Old 8th Jul 2020, 7:16 pm   #17
PJL
Lawrence.
Your theory could be close, maybe Beethoven ordered a load of cabinets and the chassis didn't fit so they reworked by slapping an outer panel on the front.
PJL is offline
Old 9th Jul 2020, 2:14 pm   #18
Peter73
Default Re: Beethoven 4 valve set, Identified as a model 99.
Thanks very much PJL for identifying my set, much appreciated.
Pete.
Peter73 is offline
Old 9th Jul 2020, 3:13 pm   #19
McMurdo
McMurdo's Avatar
rather a nice set, are you going to restore it?
Kevin
McMurdo is offline
