Old 10th Jul 2019, 9:21 pm   #1
mikko rintala
Default AVO CT 160 digital panel current meter
Mikko hey. I'd like to try the digital panel meter through the front panel A1 and A2 anode connectors. How big resistor I have to put in to avoid the overvoltage relays going on. With an analog panel gauge, this works great. But I would like a digital one.
mikko rintala is offline
Old 11th Jul 2019, 8:05 pm   #2
Ed_Dinning
Default Re: AVO CT 160 digital panel current meter
Hi Mikko, for initial tests it would be as well to use a separate battery powered DVM.
Drawing DVM meter supplies from mains or the tester itself is full of dangers due to possible common mode problems.
Note that this can also be a problem if you take a digital output to a computer for data logging/ curve tracing.
Ed
Ed_Dinning is offline
Old 11th Jul 2019, 9:44 pm   #3
mikko rintala
Thanks. The purpose would be to use a link power meter with its own 5v battery. What size would it be good to put in the resistance that the measurement would remain true?
https://www.ebay.com/itm/DC-100mA-Re...MAAOSwOeVZzl-y
