Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 10th Jan 2020, 3:49 pm   #1
ajs37
ajs37's Avatar
Default Set of 7 knobs for an Armstrong 226 Tuner/Amplifier
Hi - I have owned one of these since the early 1970s - it was in a poor physical state when I got it and never had the right knobs on it. I used it for a while then stored it, promising myself that 'one day, I will.....'. Well we've all been there and that day has come.
So first off, I need a complete set of knobs - 7 of them - they do not need to be original, but they should look right - about 25mm diameter, about 15mm deep, with 6mm(1/4") shaft, fixed with a grub screw. If they have an indicator 'spot' on them, all the better!
Anybody got a supply of these (or know of a supplier?) The internet searches are driving me mad with 'knurled shaft fixing' and less that accurate descriptions - please help me if you can
Andy
ajs37 is online now
Old 10th Jan 2020, 8:20 pm   #2
Restoration73
Restoration73's Avatar
Default Re: Set of 7 knobs for an Armstrong 226 Tuner/Amplifier
There are lots of knobs around, e.g.
https://cpc.farnell.com/multicomp/mc...tic/dp/SW05852
but a lot of these are 6mm round shaft, your Armstrong will have 1/4" shafts (6.3mm)
and you may have to enlarge the hole with a pillar drill - remove the grub screw first.
Restoration73 is offline
Old 10th Jan 2020, 8:35 pm   #3
ajs37
ajs37's Avatar
Thanks - I have ordered a similar knob from Rapid with a 6.35mm hole, but I'm still not happy with the look - they are cheap though! There are other knobs without the ally hat and just a dot on the skirt which may be ok, but they are more expensive and they are still black! I'll keep looking - thanks very much for your reply
Andy
ajs37 is online now
Old 11th Jan 2020, 3:06 am   #4
teetoon
https://www.ebay.co.uk/itm/10-Hi-Fi-...AOSwAetdBUBeHi Andy. I don't know if this would be of interest but I can see 4 of the original grey knobs in this lot :- https://www.ebay.co.uk/itm/BIG-JOB-L...wAAOSwSMZeE6bo
Edit :- when I tried to edit and post the second idea it all went a bit wrong but the 2 links appear to work still.
David.
teetoon is offline
Old 11th Jan 2020, 8:21 am   #5
snowman_al
snowman_al's Avatar
Yes I can see 4 in the listing above as well.
And I have another 4 if you want to make a set. (Just a couple of set screw / nuts missing, but presentable.)
Alan
Never Leave Well Enough Alone...
snowman_al is offline
Old 11th Jan 2020, 11:38 am   #6
ajs37
ajs37's Avatar
ah! what good eyes you both have! I will attempt to win that auction David, and if I could buy the other 4 knobs from you Alan, I'd be grateful.
If you give me details (via PM) I'll do the necessary to get the money to you - I can do paypal as well as bank transfer
Thanks again!
Andy
ajs37 is online now
Old 11th Jan 2020, 4:46 pm   #7
See_Mos
I have one, why only one is a mystery. It's a bit grubby but should clean up OK.
If you need it PM your address.
See_Mos is offline
Old 12th Jan 2020, 11:35 am   #8
ajs37
ajs37's Avatar
Yes please! - I'll PM you!
thanks
Andy
ajs37 is online now
Old 14th Jan 2020, 11:36 am   #9
ajs37
ajs37's Avatar
well, I didn't win that auction - the knobs went for 23 in the end!!!
Never mind - I have been promised 5 and I have a couple that are similar (wrong colour)
Thanks for all the help - especially See_Mos and snowman_al!
If anyone else comes across these knobs, I would be grateful to know
Andy
ajs37 is online now
Old 21st Jan 2020, 2:54 pm   #10
See_Mos
The batch of knobs that Andy bid on have reappeared on EBAY at 9.99 EACH plus 1.60 post.
See_Mos is offline
Old 27th Jan 2020, 1:14 pm   #11
ajs37
ajs37's Avatar
wow! I'm not going to bid on them! - thanks again to See_Mos and snowman_al for the knobs (and I won't be selling them either!)
Andy
ajs37 is online now
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
