Old 2nd Jan 2020, 3:54 pm   #1
Pete_kaye
Pete_kaye's Avatar
Default Home made earphones
A few years ago , I made some simple crystal earpieces from old fire alarms . I fitted 47K across each one and they all worked fine . Yesterday I tried them again with crystal set and only one worked. I got readings of v. high resistance with my meter but not a peep .Do these earphones disintegrate with lack of use? Shall I just bin them?
Pete_kaye is offline
Old 2nd Jan 2020, 4:09 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: Home made earphones
do you mean you used the type of 'sounder' things that are a flat brass disc with a piezoelectric element bonded to one face?
This sort of thing: https://uk.farnell.com/multicomp/abt...30v/dp/1675548
or the similar ones in a small circular plastic case.
G6Tanuki is offline
Old 4th Jan 2020, 12:38 pm   #3
Pete_kaye
Pete_kaye's Avatar
Yes. I did not explain earlier very well that the high resistance readings were only when the 47 K was disconnected.
Old 4th Jan 2020, 3:58 pm   #4
It would be high, only ceramic twixt the probes. Ceramic sounders last for ages (as long as clay pots I suppose which is a very long time).
Old 5th Jan 2020, 6:26 pm   #5
Biggles
We scrap quite a few old style (80's ish) phones at work (and yes, they really are well beyond repair!) and I have found that using two earpieces from them connected in series make a usable set of phones with medium impedance for things like crystal sets. They seem quite sensitive too. I always find crystal earpieces sound a bit thin and tinny for my liking.
Biggles is offline
Old 8th Jan 2020, 5:07 pm   #6
Pete_kaye
Pete_kaye's Avatar
they've gone in the bin . It is easy to get bogged down in trivia.
Old 13th Jan 2020, 5:30 pm   #7
daviddeakin
daviddeakin's Avatar
"earpiece from fire alarm" is the most bafflingly wonderful thing I've heard all day
daviddeakin is offline
