25th Oct 2021, 7:19 pm | #1 |
Might Just Keep This As A Display Piece
Just got this Philips 581A/15 Bakelite case radio. It's in reasonable nick except for a crack to one of the sides that has been repaired in the past. It looks to be largely untouched on the inside.
What do members think? is it a decent set and is it worth getting working? It's missing its 'Philips' badge on the front does anyone know if these are available anywhere? |
25th Oct 2021, 7:25 pm | #2 |
Re: Might Just Keep This As A Display Piece
If it doesn't actually _work_ I wouldn't give it house-room.
[I've got various radios whose cabinets were damaged/wormy - I happily threw out the cabinets and restored the underlying chassis to better-performance-than-new. There's nothing wrong with 'naked radios' ].
25th Oct 2021, 7:51 pm | #3 |
It's a good sounding radio with very good sensitivity and selectivity. Made c.1949.
Edward. |
25th Oct 2021, 8:03 pm | #4 |
It looks in good clean condition to me. I'd restore it.
Does it have a back? Service info here:- https://www.service-data.com/product...10/5873/m14610
25th Oct 2021, 8:04 pm | #5 |
I think it's quite attractive. Do you like it? I bet someone has a smashed set, and so one of those badges, somewhere...
"The best dBs, come in 3s" - Woody Brown |
25th Oct 2021, 8:13 pm | #6 |
I'd restore that - looks a nice set.
25th Oct 2021, 8:17 pm | #7 |
Does Bakelite get woodworm? Splendid set, and all radios need to work, wonderful things they are.
25th Oct 2021, 8:19 pm | #8 |
As for "What's going on here" those two capacitors don't appear on the chassis layout in the service sheet. You'll have to trace where they're wired to. Bear in mind that capacitors in series follow the 1/C1 + 1/C2 =1/C3 rule.
The electrolytic cap C3 is supposed to lay flat next to the mains transformer, but I can't see it in your picture.
25th Oct 2021, 10:33 pm | #9 |
It looks rather classy, I would get it working and keep it.
25th Oct 2021, 10:50 pm | #10 |
I cannot see an output transformer unless the speaker is one of those special high impedance types. The rectifier valve position is rather interesting as well! I expect that the Philips badge was common to much of the range of radios from this era so maybe search for a poor example of a wooden cased receiver.
Christopher Capener
25th Oct 2021, 11:26 pm | #11 |
Philips knew what they were doing and were quite creative, bordering on adventurous.
It looks to be an interesting set. The question of what to do with it is yours and yours alone to answer. Do you need another working table radio? Do you think it's interesting or attractive enough to be a keeper? It comes down to your opinions, needs and interests. If you decide it's not for you, it isn't landfill material, there will be plenty of people interested. An odd collection of valve bases! definitely Philips looking in the back. David
26th Oct 2021, 10:20 am | #12 | |
Lawrence. |
1st Nov 2021, 8:41 pm | #13 | |
Case coming along nicely. The re-painted lines appear White in the photographs but are actually Ivory Last edited by _Garak_; 1st Nov 2021 at 8:47 pm. Reason: Added text |
1st Nov 2021, 8:55 pm | #14 |
Those caps do look distinctly dodgy, but appear to have been added a long time ago, if not in the factory. If you ever get around to restoring it electrically, it's probably best to revert to the circuit diagram then treat any exposed faults as new.
Nice looking set. You can clean all the speaker soot out with some mild vacuuming or maybe a bit of foaming cleaner and a soft paintbrush. Don't overdo it though, or the fabric glue may dissolve. |
1st Nov 2021, 8:55 pm | #15 | |
Looks like those two caps are wired in series (double the voltage, half the value) between cathode and one anode of the rectifier so possibly an attempt to cure modulation hum. Why only one of the anodes I have no idea...... Odd line up of valves, mixture of loctal and B8A. I'm guessing the first loctal is an ECH21 and the other is an EBL21. It then seems to have two EAF42's? I wonder if one of those is wrong? No it's right!! Just checked the circuit. Two IF amps would make it a very sensitive set. Even more reason to sort it out properly and get it working.
There are lots of brilliant keyboard players and then there is Rick Wakeman..... Last edited by Sideband; 1st Nov 2021 at 9:24 pm. |
1st Nov 2021, 9:45 pm | #16 |
Hmmm had a closer look. It seems one of the EAF42's is used as an AF amp/detector so still only one IF amp. Still it's unusual enough to restore.
