Old 14th Apr 2021, 7:20 pm   #1641
ajgriff
ajgriff's Avatar
Default Re: Non-working Commodore PET 3016
Originally Posted by Slothie View Post
From my memory the paint on my 2001 was a sort of silk white with little lumps in it (similar to the old "eggshell" paint). It wasn't particularly "gloss", more like that textured finish you get on plastic casings but less well defined.
Reminiscent of spray painting defects that you might expect from a manufacturer of budget office furniture! I think it would be a mistake to overestimate the quality of the finish. For example I could see no evidence to suggest that a primer was used.
Alan
ajgriff is online now
Old 14th Apr 2021, 7:26 pm   #1642
Mark1960
Originally Posted by ScottishColin View Post
I'm not really up for the expense of getting matched paint at an automotive supplier.
I think its still worth going to an automotive paint factor even if you don’t bother to get a matched paint.
They used to fill spray cans for touch up, cellulose paint, that were significantly better for spraying than the cans you get in halfords and other similar places. Much better coverage and propellant and not much more expensive. I’m talking about 25+ years ago so regulations on what they can supply may have changed.
Mark1960 is offline
Old 14th Apr 2021, 7:52 pm   #1643
Slothie
Alan
Yes, I think the only nod to quality was that the paint outside was fairly thick. Plenty of semi-visible metal on the inside!
Slothie is offline
Old 14th Apr 2021, 8:08 pm   #1644
SiriusHardware
Colin didn't say how the unit was marked with the postcode (Of Kendal College, Cumbria). Engraved? Stencilled? It would be a pity if that historic detail was lost. If it can't be preserved on the outside then maybe it could be re-inscribed or painted on the inside.
I'm wondering now if the machine was disposed of by the college in an already electronically ruinous state - the educational environment is a notoriously tough one for anything to have to survive. If so, Colin may be the first person to see it working since it last worked there. It's just a shame that the interim owner didn't keep it in a drier place.
SiriusHardware is online now
Old 14th Apr 2021, 8:19 pm   #1645
ScottishColin
It's a bit, er, maunual. Like you, I don't want to lose it either. I'll have to find away to tidy the case up but leave that bit.
https://drive.google.com/file/d/1QuC...ew?usp=sharing
Colin.
ScottishColin is offline
Old 14th Apr 2021, 8:29 pm   #1646
SiriusHardware
Mm, now I see it I think it will be difficult to eradicate the rust and still keep the engraved postcode where it is. The priority is probably to neutralise the rust otherwise it may start coming through any paint or coating you care to put on it.
I think it would be OK just to repaint it on the inside somewhere, as long as that detail stays with the machine.
Old 14th Apr 2021, 8:33 pm   #1647
Timbucus
The engraving should survive I would think it is probably quite deep - just don't fix it - you can always manually adjust the engraving after and lacquer it to stop it rusting?
Timbucus is offline
Old 14th Apr 2021, 8:35 pm   #1648
ajgriff
ajgriff's Avatar
I think the postcode will always look like a rather ugly scar. Why not replicate it on a label discreetly stuck to the serial number plate?
Modern (acrylic) proprietary aerosol sprays really are very good.
Alan
Old 14th Apr 2021, 8:41 pm   #1649
SiriusHardware
I've just been looking at Kendal College's website, they still have a computing department there. If they have an in-house magazine the survival and resurrection of this machine which obviously came from there originally would make quite an interesting story for them. We have to hope, of course, that it was officially disposed of / acquired legitimately all those years ago.
Old 14th Apr 2021, 8:46 pm   #1650
ScottishColin
Funnily enough, that's next on my list - to contact them to let them know.
I'm playing Chess right now. it's great to be able to play some games that bring back memories.
Colin.
Old 14th Apr 2021, 8:47 pm   #1651
ScottishColin
Does anyone know how to get the labels off so I can paint the PET - I think my masking skills won't be up to it, and there's always the possibility that there is rust under the labels that needs got rid of too.
Colin.
Old 14th Apr 2021, 8:58 pm   #1652
SiriusHardware
There's isn't a chess player in the world, human or otherwise, that can't trounce me at chess so it's not exactly my favourite game.
My best guess would be that the labels / decals will come off more easily when the metalwork is quite warm. Not having seen one close up I assume the main 'PET' logo is printed on a bit of brushed aluminium which is stickied onto the casing, probably in a slight hollow just the right size and shape. This is definitely not my area, though.
Old 14th Apr 2021, 9:06 pm   #1653
ScottishColin
The label is vinyl and glued on - not the original aluminium type.
On the IEEE subject, is the code on page 184 of this PDF worth typing in to try?
http://www.1000bit.it/support/manual...EEE488_Bus.pdf
Colin.
Old 14th Apr 2021, 9:10 pm   #1654
Slothie
My PET had a vinyl-like sticker with a metallic foil backing that would be hard to remove without tearing as its quite thin. Perhaps some kind of solvent and a q-tip and a huge amount of care might do it...
Slothie is offline
Old 14th Apr 2021, 9:10 pm   #1655
ScottishColin
Here's the label.
https://drive.google.com/file/d/1MxY...ew?usp=sharing
Colin.
Old 14th Apr 2021, 9:14 pm   #1656
Slothie
Colin.
I used to have that book! I'd forgotten it had a test program. Yes, it would be a great idea to test with that. it will tell you if the IEEE bus drivers are working, and they have been known to fail. It will also check the 6520 that they are connected to.
Slothie is offline
Old 14th Apr 2021, 9:19 pm   #1657
ajgriff
ajgriff's Avatar
I think you'll ruin the labels if you try removing them. I doubt if rust has developed underneath the labels unless they're showing signs of peeling. Careful masking is the only answer in my view. Definitely worth buying some modellers masking tape. Just a reminder of what can be achieved:
https://www.vintage-radio.net/forum/...&postcount=185
The modellers tape is yellow in this example.
Alan
Old 14th Apr 2021, 9:23 pm   #1658
SiriusHardware
Sorry, I didn't notice that you had tried the super simple test I suggested earlier (The same test is buried in the start of that longer program, which is probably worth typing in and saving since you appear to have a working tape setup).
Anyway, the second result should be 255 (same as the number you wrote out in the second instance).
When you write out 255 (decimal) you are sending all 1s (11111111) to the output latches and when you PEEK the port you should see the same bit states coming back, but instead you are seeing 126 which is 01111110, suggesting a possible fault with bits 0 and 7 of the port.
Try that program and see what it reports. If it agrees there is a problem we'll drill down and find out whether the problem is with output to the port or readback from the port.
If you
Code:
POKE 59426,0
and then measure the voltages on the IEEE port 1,2,3,4,A,B,C,D connections all those lines should be 0V / logic 0.
If you then
Code:
POKE 59426,255
and measure the voltages on pins 1,2,3,4,A,B,C,D again, all those lines should now be at logic 1 (~3V or greater).
Old 14th Apr 2021, 10:08 pm   #1659
ScottishColin
I'll take your advice - thanks. Going to be a couple of days before I start on this I think. I need to get the rust off first and then rub it down.
Colin.
Alan
Old 14th Apr 2021, 10:31 pm   #1660
ScottishColin
OK - typed it in and run it (it makes me miss cut&paste...).
As suggested, it reports that the bad GPIB bits are 7 and 0.
Colin.
If you
Code:
POKE 59426,0
If you then
Code:
POKE 59426,255
