6th Sep 2015, 6:43 pm | #1 |
Marconi TF801A now working.
I have just finished and tested the TF801A RF signal generator and it is oscillating (CW & MCW) on all ranges from 8MHz to 260MHz. I have not only changed all the electrolytics, but replaced the EC53 triode, but also replaced the two EA50 diodes with Silicon BAW62 signal diodes. I am getting 330mV P-P wirh 0dB on the attenuator on the 8 to 19 MHz range.
The inside of this instrument is a work of art! Here are some photographs. Neil
An engineer makes for a penny what a scientist makes for a pound! |
6th Sep 2015, 11:12 pm | #2 |
Re: Marconi TF801A now working.
Well done! It's nice to see some of this classic and very high quality test gear restored to working order.
7th Sep 2015, 7:25 am | #3 |
I am amazed at how stable the frequency is when set. The fine tuning offset control lets you set a very precise frequency. Also, given the quality of this instrument, the attenuators are incredible quality. I shall use this on my next valve comms receiver build!
Neil
7th Sep 2015, 10:56 am | #4 |
Congratulations on an excellent job, and for giving it a good home.
7th Sep 2015, 10:59 am | #5 |
If it is the one I recall, it is a very nice piece of kit. The one I had was lacking an oscillator valve and being unable to get a replacement, I used a FET instead. The carrier strength was a bit up & down over the range, but it did the job.
Interesting to see the Advance genny in the back. I also have one of those, not that it gets much use since I built a DDS unit. |
7th Sep 2015, 11:17 pm | #6 |
Dave,
Thanks for the generator, I ended up changing all the electrolytics for modern capacitance equivalents. All the large valves worked fine. I decided to slot the Silicon diodes into the EA50 valve holders and they also worled fine.
7th Sep 2015, 11:20 pm | #7 |
Les,
I purchased an EC53 from ebay for about £6. I thought about the FET option, but the RF level pot can apply around 200V onto the EC53's anode for some bands. I also have an Advance P1 genny which also works well.
