Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Repair and Restoration Services Wanted
Repair and Restoration Services Wanted If you need someone to repair or restore equipment for you please post your request here.
Old 12th May 2019, 2:26 pm   #1
Martyin
Default My little spinney radio.
Hello
I have a small Spinney radio 7 transistor two band radio from the 60s. It works and picks up just two stations, and the volume is really low when in the high position. It needs an Aerial. cosmetically I want leaving alone. But this radio was kept to keep the cows amused when milking on my grandparents farm, hence the inside is quite dusty. What I’m looking for is someone to revamp the inner components, as required to work properly again. Would there be anyone able to do this, in the midlands, as I would like to drop off and pick up in person. I don’t trust the post with this special radio of mine.
I appreciate this may be a tall order but any help regarding this would be great and very much appreciated.
If this is in the wrong section I apologise.
Many thanks
Martyin.
Martyin is offline
Old 12th May 2019, 3:40 pm   #2
Martyin
Default Re: My little spinney radio.
The said radio
ID:	182938   Click image for larger version
Martyin is offline
Old 14th May 2019, 11:32 pm   #3
TrevorG3VLF
TrevorG3VLF's Avatar
I could take a quick look but do not have the time to do an extensive investigation.
I am in Whatstandwell DE4 5EG - not too far from parts of Staffordshire.
You should be able to pack well enough for posting although a bump could detune the aerial. Has it been dropped?
TrevorG3VLF is offline
Old 29th May 2019, 10:18 pm   #4
TrevorG3VLF
There is a pony express running from Alsager to Whatstandwell on Tuesdays, It crosses parts of Staffordshire.
Where are you?
Old 30th May 2019, 8:17 am   #5
Station X
Station X's Avatar
The OP has not visited the forums since he posted his request.
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is offline
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
