8th Aug 2014, 8:57 pm | #1 |
Heathkit HP23A PSU
Does anyone have any info or experience of this HV PSU, please ? It can supply 900V, 300V, Heaters, and -130V.
Regards, David |
8th Aug 2014, 9:53 pm | #2 |
Re: Heathkit HP23A PSU
13th Aug 2014, 7:52 am | #3 |
I have one. It's meant to be used with the SB/HW series of tube-based ham radio transceivers put out by Heathkit in the 1960s and 1970s. There were several variations made of the HP23 series, with the A probably being the most versatile (offering adjustable bias voltage, switchable secondary B+, and a center-tapped 12.6V winding). Later versions generally lacked one or all of these features. More info can be found here:
http://www.w6ze.org/Heathkit/Heathkit_026_HP23C.pdf Attached are some pictures of my HP23A, along with the SB-600 speaker cabinet it's installed within, and the SB-102 transceiver it powers. -Adam |
13th Aug 2014, 5:52 pm | #4 |
Thanks Graham & Adam for your replies. I've managed to download the circuit diagram. Plus found a site with the 20 page construction Manual pdf. Now need to find an 11 pin connection plug. Regards, David
13th Aug 2014, 9:19 pm | #5 |
You might want to try places which sell parts for Leslie organ speakers, as the later models used a plug like that. Good luck!
-Adam |
14th Aug 2014, 1:59 am | #6 |
It looks similar to an 11 pin relay base.
I've never noticed plugs, but an old relay may be "adjustable" if so. |
14th Aug 2014, 10:03 am | #7 |
Thanks Bill for jogging my memory. I think I've an old relay lying in a gash box somewhere. Just hope it didn't get cleared out a year or two back.
Regards, David |
