Old 2nd Sep 2021, 11:23 am   #21
peter_sol
Default Re: Homebrew guitar amp, speaker mismatch
People are getting muddled with series and parallel.
Wire the bass speaker directly to the amp and the tweeter (with its cap in series with it) across the bass speaker. Maintain polarity.
peter_sol is offline
Old 2nd Sep 2021, 2:04 pm   #22
sirdavy
Capacitor aside, isn't what you are describing 'Speakers Wired In Parallel'?
I was speculating whether it might be possible to have the woofer and tweeter in series but the inclusion of a capacitor somewhere in the wiring to protect the tweeter. Is that possible? I'm out of my depth really.
sirdavy is offline
Old 2nd Sep 2021, 4:47 pm   #23
G.Castle
To do that you would need an inductance across the tweeter, it wouldn't help what you're trying to achieve with the impedance.
You say you're not worried about the efficiency, so why not just put the extra 8-10 ohms in series with the speaker as was suggested to you before? If you want a little more top end to the sound you could put a non polarized capacitor of up to a few microfarads across that resistor.
G.Castle is offline
Old 2nd Sep 2021, 5:05 pm   #24
sirdavy
Yes, reckon I will do exactly that. I've got an L-pad on its way and I'm going to put a cap on that to let through some of the higher end. I'm guessing I would need to repeat the same value cap across the resistors too?
sirdavy is offline
Old 2nd Sep 2021, 5:34 pm   #25
G.Castle
Doing that you may as well go straight across with one cap.
G.Castle is offline
Old 2nd Sep 2021, 5:44 pm   #26
sirdavy
Thanks! What would a good value cap be? On a guitar amp attenuator I put together I used a 6.8uf capacitor on a switch to make the sound brighter at lower volumes. Would the same value work here?
sirdavy is offline
Old 2nd Sep 2021, 5:52 pm   #27
G.Castle
Personal taste can't be analysed, it can't hurt so try it! The higher the value the lower frequencies then start getting through it would be a good place to start.
G.Castle is offline
Old 2nd Sep 2021, 9:44 pm   #28
sirdavy
Great. Thank you, G.Castle.
sirdavy is offline
