Old 19th Apr 2023, 9:15 pm   #1
Tractionist
Default Cloudy/Yellowed TR82 Dials
Someone posted a question as to whether the 'Restobright' process worked on [formerly but now cloudy/yellowed) Bush TR82 tuning dial 'knobs' - but I couldn't locate the OP (sorry mods).
Well, I have a few of these - some of which I've attempted to re-cut with appropriate paste hitherto - without success. But fuelled with 'the joys of Spring' and abundant sunshine - I thought I'd give one the 'Restobright' treatment.
Result! It does seem to work and certainly doesn't do them any harm. I've got one 'cooking' at present and it certainly seems to be much improved.
Unfortunately I didn't take any 'before' photos - but if anyone is interested I will post some 'after' shots.
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 20th Apr 2023, 7:28 pm   #2
Philips210
Default Re: Cloudy/Yellowed TR82 Dials
That's good to know Retrobright works.
I've had limited success with paint cutting paste such as T cut when the yellowing is only slight. For very discoloured dials I've used a very fine wet and dry abrasive paper, typically 1200 or 1000 grit and then progress to a cutting compound. It can take a fair old effort to obtain good results but should be successful given a little patience. Brasso may be worth trying too.
Regards,
Symon
Philips210 is offline
Old 20th Apr 2023, 9:27 pm   #3
paulsherwin
paulsherwin's Avatar
Cutting compounds don't work because the discolouration is too deep. I didn't know that the Restobright process works with cloudy transparent plastic - thanks for the info.
paulsherwin is online now
Old 21st Apr 2023, 4:32 pm   #4
locknut
Certainly good info, I wouldn't have thought to try that.
Paul
locknut is offline
Old 21st Apr 2023, 9:47 pm   #5
Tractionist
Attached progress to-date - it's not perfect, but greatly improved ..... this was a particularly 'sad specimen' featuring some sort of etched or superglue type staining on the outer face too (so I cut and polished it after the Restobright treatment.
Name:	TR82 Dial Finished.jpg
Old 22nd Apr 2023, 11:56 am   #6
Tractionist
A couple more shots for your routine edification:
ID:	277166   Click image for larger version
