Old 21st Apr 2016, 8:30 pm   #21
peter_sol
Default Re: Dynatron Henley RG33W radiogram
That instruction book covers all those models. it does not mean that the Henley is a RG33W
peter_sol is offline
Old 21st Apr 2016, 8:52 pm   #22
Vintage84
I read it as the Henley being the RG33 and Richmond the RG34, etc.
I believe my model is the RG33W.
Vintage84 is offline
Old 21st Apr 2016, 9:08 pm   #23
Vintage84
Here's a couple of photos of the radio section. The back of one of the valves looks like it could be a problem...
I'll try to find the service documents so that I can change any dangerous capacitors, etc. Which are the capacitors that are likely to cause problems?
ID:	123231   Click image for larger version
ID:	123232   Click image for larger version
ID:	123233   Click image for larger version
Old 22nd Apr 2016, 12:00 am   #24
Edward Huggins
You don't need to change capacitors for the sake of changing them! The key caps will be those associated with smoothing, cathode bias and inter-valve coupling - but if you have no previous experience, then don't start on this without getting some hands-on support from a Member of this Forum. It's a super unit and worthy of attention, but of the right kind. Edward
Edward Huggins is offline
Old 22nd Apr 2016, 8:23 am   #25
Nickthedentist
Nickthedentist's Avatar
So did I.
It looks like a really well-built machine, and the chassis is in virtually mint condition.
N.
Nickthedentist is offline
Old 22nd Apr 2016, 8:34 am   #26
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
I'd replace all those Red & Yellow Plessey Electrolytics for a start. To me they have become 'replace on sight' in anythiing!
'LIVEWIRE?' is offline
Old 22nd Apr 2016, 9:23 am   #27
julie_m
That's an impressive array of glassware I think I can spot an EZ81, ECC83 and four ECL82s. It should certainly have plenty of oomph when it's turned up!
The most important capacitors to replace are the DC blocking capacitors on the grids of the pentode sections of the output valves, because they can cause a nasty cascade failure if leaky.
julie_m is offline
Old 22nd Apr 2016, 9:53 am   #28
Nickthedentist
Agree with both posts 25 and 26.
Note that the RG33S seems to be an entirely different beast, being all-transistor. Also, the RG22/3 is a lesser machine with a mere 5 valves, and as Graham implies, the "Cliveden" is the RG23 not RG33 as Paul describes it in the index.
OTOH, the RG21 is described as using 9 valves. Is your line-up: ECC85 ECH81 EBF89 ECC83 EM84 ECL82 ECL82 ECL82 ECL82?
http://www.service-data.com/section..../1/rg21-henley
Old 22nd Apr 2016, 10:02 am   #29
peter_sol
It was silly of Dynatron to use the same numbers for completely different models.
Who knows what the prefixes of "W" and "S" stand for.
"S" maybe Solid State.
Old 22nd Apr 2016, 10:06 am   #30
Nickthedentist
Yes!
It may be that the numbers are the cabinet style and the suffixes represent the chassis fitted, i.e. the opposite way round to normal practice.
Old 22nd Apr 2016, 10:33 am   #31
ronbryan
Nick seems to have got it in one (post 27). The RG21 is a "Henley" according to the R&TVS sheet.
Ron
ronbryan is online now
Old 22nd Apr 2016, 11:44 am   #32
Station X
Station X's Avatar
There must be more than one "Henley". This issue of Wireless World from 1964 shows a picture of a Dynatron Henley Model RG33W on page 441.
http://www.americanradiohistory.com/...ld-1964-09.pdf
Graham. Forum Moderator
Station X is online now
Old 22nd Apr 2016, 11:49 am   #33
peter_sol
Judging from the photo's, that is the one vintage 84 has, so he was correct.
All most confusing.
Old 22nd Apr 2016, 12:01 pm   #34
Station X
Station X's Avatar
Given that this radiogram worked before the piano keys were lubricated and the fuse blew, perhaps the best course of action would be to replace the fuse and see whether it still works.
If it does then selective capacitor replacement would be in order. Perhaps the grid couplers and the Plessey electrolytics?
Old 22nd Apr 2016, 12:25 pm   #35
Vintage84
That's the one (see attached).
I believe there are 9 valves, but will confirm the order tonight.
Unfortunately, replacing the fuse didn't do anything... Are there any obvious things I should check first?
Old 22nd Apr 2016, 12:34 pm   #36
Nickthedentist
Have you got a multimeter, and do you know how to use it?
Old 22nd Apr 2016, 12:42 pm   #37
Station X
Station X's Avatar
One simple thing to check is whether the valves light up.
Old 22nd Apr 2016, 12:46 pm   #38
Vintage84
Yes, I have one and know how it works - just haven't ever used it for testing this type of kit!
Old 22nd Apr 2016, 12:52 pm   #39
Nickthedentist
As a start, unplug the machine, set the meter to its lowest ohms range, connect the probes to the plug's L and N terminals, and see what the meter says both with the power switch on and off.
If the primary of the power transformer, its wiring, switches and fuses are OK, you should read a few tens of ohms with the switch on, and infinity (1- on a digital meter) with it set to off.
N.
Old 22nd Apr 2016, 8:52 pm   #40
Vintage84
Hi Nick,
Just checked this and it performs as you described.
The valves aren't lighting up.
