Old 30th Oct 2020, 6:10 am   #1
AVKazak
Default Sony TC-630: repair of broken shaft
Greetings!
Recently the shaft moving the take-up idler got broken and detached from the main part (see attached).
Can you share ideas on its repair, please?
Or replacement (NOS or used parts available?) is the only option?
Thank you.
ID:	219194   Click image for larger version
AVKazak is offline   Reply With Quote
Old 30th Oct 2020, 7:21 pm   #2
DMcMahon
DMcMahon's Avatar
Default Re: Sony TC-630: repair of broken shaft
Hello / Здравствуйте,
You call it a shaft but is it the part identified as item # A48 in the attached PDF section drawing ? In the Sony parts list this part is X-34440-08 Slider Ass'y (C)
Difficult from your photo to see the damage clearly, but looks like it could be very difficult to do a repair.
Also could be very difficult find a used or NOS replacement part. If you could find someone scrapping a TC-630 for parts that may be the best option of sourcing the part.
Are you able to get a better/closer photo of the damaged area ?
DMcMahon is online now   Reply With Quote
Old 30th Oct 2020, 7:48 pm   #3
If it's the upright that's snapped off and I had that problem and nothing else was forthcoming I would attach it back again using a small steel "L" bracket fixed with a couple of rivets and solder around the joints for extra security.
(countersink hole(s) to take flush rivet(s))
ms660 is online now   Reply With Quote
Old 31st Oct 2020, 2:21 pm   #4
Silicon
Jewellers or model makers might have brazing or TIG welding facilities.
They could add extra metal to make it stronger than the original design.
Silicon is offline   Reply With Quote
Old 31st Oct 2020, 3:04 pm   #5
Ken
Ken's Avatar
I agree with Silicon. If it can be removed I think it looks thick enough to be welded. I think mig might be best as I think the heat could be kept a bit more localised. I've only had experience with mig and oxy-acetylene so I'm open to correction with tig as far as heat localisation is concerned.
Ken.
Ken is online now   Reply With Quote
Old 31st Oct 2020, 3:42 pm   #6
Mike Phelan
Mike Phelan's Avatar
I'd go for Silicon's brazing or silver-soldering option; less heat than welding.
Mike.
Mike Phelan is online now   Reply With Quote
