Old 21st Jul 2020, 9:47 am   #1
Blivit42
Default Odd 706
Hi, I have a 706 telephone that seems to be non-standard.
I had two of these phones that I got from the same person. I tried converting them, one worked, the other didn't. The incoming line went off for a short time, so I assumed there was a short and I started to look for faults and tracing the internal wiring.
It seems to be an early version of the 706 without a PCB. I noticed two odd things.
1) The Automatic Sensitivity Regulator is missing and only the terminals A, C & E are fitted. The 706 phone should work with the regulators reversed, which would connect terminals B, C and D, but since B and D are missing, this won’t do anything.
2) The Induction coil No. 31 is missing and doesn't seem to have ever been installed. Maybe someone has removed it.
There is a wiring schematic N112419/4 pasted inside the cover of the phone which doesn't show the induction coil or the regulator, so I don't think it has been altered. It differs from the wiring shown on standard N806 diagram.
Can anyone tell me what this phone might be and if could be converted? I suspect it may have been a special for an extension, which won't work on its own.
Thanks for any help.
Blivit42 is offline
Old 21st Jul 2020, 10:03 am   #2
Dave Moll
Dave Moll's Avatar
Default Re: Odd 706
See https://www.britishtelephones.com/ericsson/n1900.htm for more information about this model of telephone.
Dave Moll is offline
Old 21st Jul 2020, 10:05 am   #3
Nickthedentist
Nickthedentist's Avatar
Default Re: Odd 706
Yes, it's basically a cost-reduced Ericsson phone designed for use as an extension on a private exchange like you might find in a big office or factory etc.
It will work on a normal BT line.
Nick.
Nickthedentist is offline
Old 21st Jul 2020, 10:12 am   #4
Blivit42
Default Re: Odd 706
That's it, thank you very much. Several hours of Googling had failed to turn up that connection. I will read that and come back if I'm still baffled.
Blivit42 is offline
Old 21st Jul 2020, 10:13 am   #5
Dave Moll
Dave Moll's Avatar
Default Re: Odd 706
Perhaps an image of how yours is wired might give a clue regarding why it isn't working.
Old 21st Jul 2020, 12:18 pm   #6
Blivit42
Default Re: Odd 706
Thanks, I'll have another look at it this evening and will take some pictures tomorrow.
Blivit42 is offline
