20th Oct 2021, 7:30 am | #1 |
Minstrel record player transistor
this was gifted to me last night anyone know the maker just state made in Great Britain on the back
20th Oct 2021, 7:32 am | #2 |
Re: Minstrel record player transistor
More pictures, had to remove the grill which is held on by double sided tape to get the amp out
20th Oct 2021, 8:56 am | #3 |
This was made by FIDELITY in c.1966. It's an early discrete transistor (pre-chip) version.
Edward. |
20th Oct 2021, 9:07 am | #4 |
Looks very similar to the player in this thread, although the amplifier is different:-
https://www.vintage-radio.net/forum/...d.php?t=148163
20th Oct 2021, 9:16 am | #5 |
thanks folks does look like one of these, had a look at the forum DVD's sadly not on them but there are model numbers missing so i guess we do not have circuits for the full range
20th Oct 2021, 9:24 am | #6 |
I think that once Fidelity started using semiconductor amplifiers they chopped and change quite a bit with externally identical players likely to contain different amplifiers.
The IC based amplifier in my Fidelity HF42 is nothing like the transistor based amplifier shown in the service sheet.
20th Oct 2021, 9:45 am | #7 |
Looks like a Fidelity HF45 to me. Circa 1972.
Regards, Ben. |
20th Oct 2021, 9:46 am | #8 |
You could have just taken out the two screws that hold the amplifier to the panel without dismantling the cabinet front.
20th Oct 2021, 9:50 am | #9 | |
there are no screws around the turntable either |
20th Oct 2021, 9:54 am | #10 |
20th Oct 2021, 10:29 am | #11 |
Fidelity could have made it for furniture shops, quite common in the 60’s and 70’s. The shop probably wanted it seem to be their own design.
Frank |
20th Oct 2021, 10:38 am | #12 |
That's exactly what I had to do although the grille on mine had obviously been removed before. I stuck it back with double sided tape.
20th Oct 2021, 12:46 pm | #13 |
You remove the BSR deck by putting your hand through the front opening you now have, and pushing up the two retainer fasteners on the transit screws so that they are upright. Then lift the whole deck out. Easy when you know how. Fidelity built these for a range of different outlets/sale channel. Very cheap and cheerful.
Edward. |
20th Oct 2021, 1:30 pm | #14 |
That has to be the cheapest and most unserviceable way to make a record player. Probably thought the customer would just throw it away when it went wrong.
20th Oct 2021, 1:37 pm | #15 |
Most of them didn't go wrong though. They got consigned to the attic when the owner bought something better or switched to CD's. They then started to deteriorate with the grease hardening etc. The new interest in "vinyl" means that more and more of these players are being retrieved from attics and sold on.
Then the new owner joins these forums and we all know what happens then............
20th Oct 2021, 1:47 pm | #16 |
Late to the party!
The case is unmistakeably Fidelity, but if I'd seen the amplifier on its own I'd have guessed at one of the BRC clones. The circuitry will be pretty conventional though, nothing to cause any headaches. |
20th Oct 2021, 1:50 pm | #17 |
Fidelity also did a "valve" Minstrel.
The front panel of the record player in question looks very similar to the Co-op/Defiant MP12. Lawrence. |
20th Oct 2021, 1:57 pm | #18 |
good call a web search found this image with a loose model label in the corner where mine shows Minstrel
20th Oct 2021, 2:03 pm | #19 |
The MP12 had a different lid, the lid on the Fidelity Minstrel (the valve job) looks similar to the one on yours so far as I can make out.
Lawrence. |
21st Oct 2021, 5:24 pm | #20 |
Circuit diagram for both transistor and IC versions:
https://www.vintage-radio.net/forum/...=171605&page=2 |
