13th Oct 2021, 10:10 am | #1 |
Military Radio Spares Kit
Cycled out to Melksham Arcade yesterday afternoon and bought this for £6. It is a spare lamp and fuse kit, possibly for Larkspur or maybe later Clansman. We could not remove the lid in the shop so I was keen to buy just to see the contents. Opening up the box revealed no contents apart from two very substantial rubber inserts which contributed to the heavy weight of the box which added to the mystery. I decided to refill the box as best as I could with period lamps and fuses, there should be some small tools as well to facilitate removal and insertion of the spares, I will try to source these.
Neil
13th Oct 2021, 5:42 pm | #2 |
Re: Military Radio Spares Kit
According to this: https://www.iwm.org.uk/collections/item/object/30118194
it was part of the support kit for the Larkspur C11/R210 installation.
15th Oct 2021, 4:21 pm | #3 |
I recall coming across these boxes at various times in my service career but my memory of exactly where and when has sadly faded. While it may well have been with C11/R210 I think it was more likely to have been with VRC353Z and/or VRC321 in multi-set installations. Having said that, it could equally have been with C50/R236, Bruin, CSSH, Wavell, Ptarmigan or IARRCIS or any of the myriad other things that I came across.
My suspicion is that these boxes were common items and associated with an installation (such as "Station Radio VRC353 in Truck 3/4 Ton FFR") rather than a particular equipment. After all, even with a 3-set installation, you probably only need one set of fuses. Oh and you'd need spares for any harness or ancillaries that were part of the installation too. The wording on the box ("Electronic Equipment" rather than "Station Radio") also suggests to me that they may have been used across a broad range of installations and not just Comms. Hugh Last edited by Stockden; 15th Oct 2021 at 4:40 pm. Reason: Afterthoughts |
15th Oct 2021, 4:51 pm | #4 |
Just looking at the photo gives a waft of that ex-military radio rubber smell.
15th Oct 2021, 6:44 pm | #5 |
There's indeed something nostalgic about the aroma of opening-up a 'hermetically sealed' military radio or vacuum-packed "full standard packaging' parts.
I guess the stores-guys at .mod.uk stores places like COD Donnington would get high on the smell...
15th Oct 2021, 8:29 pm | #6 |
Yes, I can confirm that the smell of the freshly opened box was indeed very rubbery. It sits rather nicely alongside the R209 being of a similar era. There must be a fair number of these out there, with or without contents.
Neil
