16th Oct 2021, 5:44 pm | #21 |
Re: Lafayette HA-350
Hi folks. The Cheap Chinese meter arrived today and I've fitted it. The scale sizes weren't exactly the same but I managed to photocopy the old dial and print a paper sticky to cover the dial on the new meter. It doesn't look too shabby. Unfortunately there is a large protruberance at the back of the replacement meter that fouls the RF amplifier valve but I've got around that by mounting the meter slightly higher up. I've now found why the old meter might have failed. If you look at the circuit then you can deduce that the meter deflection is caused by the offset between the V6 grid 2 voltage and the cathode voltage (via potential dividers). Because this set has silicon diode HT rectifiers the HT comes up straight away before V6 has warmed up and begun to conduct. Therefore, there's a large positive offset voltage at the meter and it hits the stop. Once V6 conducts, all is well. I don't want to trash another meter so I'm pondering what's best. I could fit a standby switch in the S-meter leads but I have to remember to turn it off when the set is turned off. I can see now why somebody fitted the transistor S-meter driver mentioned earlier; I wouldn't use that circuit but I'm thinking of a single transistor amplifier taking the AGC voltage as control signal. Any thoughts welcomed. Cheers, Jerry
17th Oct 2021, 4:36 pm | #22 |
I lashed up a circuit using a BC557 PNP with the S-meter in the collector load and the transistor's base taking bias via a 1.2M potential divider off the AGC line. In principle, the S-meter worked but there was too much loading of the AGC line which took the AGC voltage at strong signal input from -6.8v down to about -4.0v which is no good. I've found a few example circuits using FETs so I'll have another go. Cheers, Jerry
17th Oct 2021, 10:18 pm | #23 |
Here's a link to the circuit that I am thinking of using http://www.pan-tex.net/usr/r/receivers/ssmeter.htm. However, I'm not sure that the polarity of the diode protecting the FET gate is correctly shown. Since AGC is negative (in my case about 0v to -6.8v) surely the diode as drawn would simply short circuit the AGC line? Shouldn't it be the other way round, or am I missing something?
18th Oct 2021, 8:05 am | #24 |
Maybe a simpler solution would be to use a 1N4148 diode shunt across the meter to bypass the excess dc at switch-on. The meter has a resistance of approx 1k and FSD 500uA means it needs only 0.5v (i.e. below the diode cut-off at 0.6v) therefore I think this should work and I can keep the S-meter circuit otherwise the same.
18th Oct 2021, 10:28 am | #25 |
Yep, the diode worked a treat. The meter now swings over to max at switch-on, but only just max, and isn't hard against the stop. After about 15 seconds the valve starts conducting and the meter drops to zero. An adequate fix. I'm still not convinced the FET circuit hyperlinked in post #23 would work properly as-drawn since it permanently limits the AGE line to -0.6v. Jerry
22nd Oct 2021, 12:51 pm | #26 | |
It looks as if the manufacturers were aware of this, but didn't think it merited some extra components! The diode across the meter is definitely a good idea though.
John G4FDD G-QRP 431 |
