Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval. |
12th Dec 2021, 12:28 pm | #1 |
Can't post a reply...
...to this thread https://www.vintage-radio.net/forum/...d.php?t=186725 I was going to say potting electrolytics isn't a good idea, they have vents for a reason.
12th Dec 2021, 12:37 pm | #2 |
Re: Can't post a reply...
You can post, but all posts there go into moderation so that they can be reviewed before approval.
12th Dec 2021, 1:03 pm | #3 |
It (the forum) said I didn't have enough privileges and no text input box appeared.
12th Dec 2021, 1:06 pm | #4 | |
Just tried again and this is the verbatim reply.
12th Dec 2021, 1:08 pm | #5 |
We will investigate - that shouldn't happen.
12th Dec 2021, 1:24 pm | #6 |
Thank you.
12th Dec 2021, 2:07 pm | #7 |
Good point.... what if the new capacitor in the potting compound needs to vent? and how about thermal dissipation if it's a foam potting stuff?
The tighter you hold the steam in, the bigger the bang. A bit of silicone or hot melt etc to hold things in position seems OK, but full immersion would complicate things. It's a discussion worthy of somewhere more prominent than services offered... Worthy of its own thread. David
12th Dec 2021, 2:31 pm | #8 |
The new components are sat in potting compound, not submerged, for obvious reasons.
I have updated the thread to clarify this point.
Valve equipment repairs since 1968 https://jonsnell.co.uk Last edited by JonSnell; 12th Dec 2021 at 2:41 pm. Reason: More information added. |
12th Dec 2021, 4:20 pm | #9 | |
I see, some capacitors have the vent as a weak point on the top though. I have only re-stuffed a few big electrolytics and then I didn't bother with anything, just supported from the base with maybe a bit of sleeving on some wires. Mine didn't have to meet mil. spec. vibration, posting them may need a little cushioning say a bit of tissue wrapped around the caps.?
For really old electrolytics where the capacitance to volume ratio is low new film types will fit and last for (almost) ever. The old block and wire types can use the modern rectangular film types and they fit in a square hole nicely. Quote:
BTW still can't post a reply. |
12th Dec 2021, 4:38 pm | #10 |
Yes, we have identified the issue. Threads in that section can only be replied to by moderators. We are now deciding what to do about it. Obviously threads started to offer services are not intended to develop into general discussion threads.
12th Dec 2021, 4:58 pm | #11 |
Maybe a less terse pop up, simply explaining why not. If a member feels it is a dodgy offer perhaps a link to the moderators to mention the fact. This offer wasn't dodgy, I just wanted to point out a potential problem.
12th Dec 2021, 5:29 pm | #12 |
Administrator
As Paul says, threads in that section cannot be replied to by anyone (other than moderators). It is intended for advertising services rather than discussing the advertised services (such discussions would be better by PM with the thread starter).
We will amend the thread title and the sticky to reflect this. It is being discussed by the moderators but is unlikely to change as the original change was to avoid discussions about individual repair requirements in the section which were becoming difficult to manage. |
12th Dec 2021, 5:35 pm | #13 |
If members have any concerns about servicee offered, they should report the post or contact the moderators by PM. The mods will take action as appropriate.
I don't think the popup text can be changed, as it comes from the underlying vBulletin forum software. This isn't a common problem - in fact, I don't think it has ever cropped up before (hence the confusion in this thread.) |
12th Dec 2021, 5:40 pm | #14 |
Administrator
That is correct, there is no global option for a section that allows threads to be started but not replied to. So it had to be done as a usergroup level, hence the permission error message.
