Old 22nd Oct 2019, 9:25 pm   #1
WME_bill
Default Solartron AS1410 power supplies
I have been asked for information about the AS1414 power supply, one of the AS1410 family.
When introduced in 1964, they were well ahead of other designs as they used a pulsed SCR to switch the input feed so that the series pass transistor only had about 5 volts to drop at the chosen output voltage and the power dissipated was kept down.
I find it very convenient to use, with the current meter full scale being effectively at the current limit setting and the digital voltage setting.
I attach a specification sheet covering all models as it may be of general interest. I have the full manual and PCBoard layouts.
wme_bill
File Type: pdf AS1410 series psu_specifications-wm.pdf (814.8 KB, 118 views)
WME_bill is offline
Old 23rd Oct 2019, 12:35 am   #2
M3VUV51
Default Re: Solartron AS1410 power supplies
sounds like a clever idea,be nice to see the schematic to see how they did it.
M3VUV51 is offline
Old 23rd Oct 2019, 2:07 pm   #3
jez_145
Yes, they are a good supply and well ahead of their time as you say. Mine is still going strong (attached) though I tend to use a modern triple supply most of the time these days. I'm not sure how old it is but I've had it at least 26 years and the company I worked for must have had it even longer - probably from new. I acquired it when they were skipping old kit prior to a move.
I've attached a rough pdf, which is similar to the previous upload but includes a couple of circuit diagrams if anyone is interested.
Jerry
File Type: pdf Solartron_AS1412 & 1414 psu_circuits-wm (1).pdf (909.2 KB, 80 views)
jez_145 is offline
