7th Sep 2022, 3:07 am | #1 |
Akai 1710W as a tube amp
Hiya, I’ve seen previous threads but not found anything that was complete and also seen YouTube videos so know it is possible.
I would like to extract the amp out of my Akai 1710. I took it apart yesterday but When I unplugged the small black connector that links up the amp to the tape path it would not power on at all. So I hooked it back up. Next I connected my DAC to the line in on the akai and my phone to line in on DAC. Played some music but the sound coming out of the Akai with external speakers is barely audible. Does anyone have some step by step advice on how they managed to achieve the task of using this as an AMP. The sound is loud and clear on tape playback but input source is barely audible |
7th Sep 2022, 7:58 am | #2 |
Re: Akai 1710W as a tube amp
Are you sure you want to ruin an Akai 1710 to make MP3 music ?.
In its day it was a very fine tape deck with many thousands sold ( in Australia alone ). The amp itself is a VERY modest affair in the first place, producing something in the vacinity of 1 ( one ) watt. It will not have significant bass!!. With welcome to the forum, and my best wishes. Joe |
7th Sep 2022, 10:05 am | #3 |
Do you get the same very low volume if you try headphones ?
David |
7th Sep 2022, 10:21 am | #4 |
You are using the amplifier to do something it wasn't designed for. You will need to set the machine to record in order to get a monitor output and maybe modify the muting circuit.
As Joe says, this amplifier won't give you any great improvement over a reasonable transistor amplifierr. If you want the 'valve (tube) sound' I'd go looking for a dedicated valved amplifier which would avoid you having to use a (rather nice) tape recorder. |
7th Sep 2022, 10:24 am | #5 |
The reason the amp would not work with the black connector disconnected is probably because the mains feed runs via that connector to the micro switch which is the end of tape sensor on the tape tensioner on the righthand side.
Graham |
7th Sep 2022, 10:36 am | #6 |
So far as I can make out from the schematic, for line in through to loudspeaker for both channels you would have to disconnect the output stage dummy loads (used in record mode) from the rec/playback switch contacts and connect the loudspeakers to those contacts instead, the record/playback switches being set to record.
Lawrence. |
7th Sep 2022, 6:19 pm | #7 |
Forgot to mention, bridge contacts 14 and 15 on both channels so that the tone control works, alternatively you could do the connection modifications at the front end by isolating record/playback switch contact 3 from the rest of the circuit and connecting the output (M) from the line in sockets from to that contact, ditto for the other channel, record/playback switch set to playback.
Lawrence. |
8th Sep 2022, 1:43 am | #8 |
Thanks all for the suggestions. I have a technics RS1500 and the tape playback quality on the Akai is not the best so I barely use it now. Also can’t play 10” reels.
8th Sep 2022, 7:15 am | #9 |
As others have said you might be better making a little line stage amp, John Broskie' s CCDA amplifier is easy to build and would do the job, he also does PCB's, see - https://www.tubecad.com/2009/03/blog0161.htm & https://glass-ware.stores.yahoo.net/cclistki.html
Andy.
8th Sep 2022, 9:55 am | #10 | |
8th Sep 2022, 11:44 am | #11 |
8th Sep 2022, 11:57 am | #12 |
The loudspeakers are switched out in record, the loudspeakers impedance is substituted by the 10 Ohm dummy load resistor R016 and its counterpart in the other channel (see Post#6 etc)
Lawrence. |
8th Sep 2022, 5:07 pm | #13 |
Thanks yeah I saw your answer before was just pointing out the headphones worked. Thanks for that advice
8th Sep 2022, 9:51 pm | #14 | ||
I hate digital So to me it is still playing MP3 Joe |
8th Sep 2022, 11:03 pm | #15 |
Please stay on topic.
MP3 is a lossy codec and nothing to do with digital encoding in itself. |
9th Sep 2022, 4:40 am | #16 | |||
9th Sep 2022, 4:41 am | #17 |
9th Sep 2022, 4:43 am | #18 |
9th Sep 2022, 9:56 am | #19 | |
https://www.vintageshifi.com/reperto...ice-Manual.pdf In the Akai 1710 the dummy load resistor is shown as 8 Ohms. Lawrence. |
9th Sep 2022, 11:23 am | #20 | |
So it sounds like there is nothing wrong with the 1710W but as explained by others the speakers are muted/switched off during recording. David |
