Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay). |
4th Sep 2022, 10:28 pm | #1 |
Pye P150/P180/P191BQ Vol pot with switch
Hi, does anyone know if this 5K pot & switch from Pye P150/P180/P191BQ is used in any other Transistor Radio? I have a few with problems, track and on/off switch troubles. Thank you all in advance for your help and advice. Bush TR114 has similar pot but plastic wheel is larger diameter - it doesn't fit, I've already tried. (The innards are similar but not totally interchangeable).
4th Sep 2022, 10:41 pm | #2 |
Re: Pye P150/P180/P191BQ Vol pot with switch
any of these fit ?
https://www.ebay.co.uk/itm/254784206726 https://www.ebay.co.uk/itm/284725175933 https://www.ebay.com/itm/123801766291 There are loads of this style if you trawl around a bit I doubt the fitting a 5K pot or a 10K pot will make much difference. Cheers Mike T
5th Sep 2022, 9:29 pm | #3 |
Hi Cobaltblue, thanks for your reply.
I've tried the first two you mention; there's not enough space to accomodate them. The third one you mention (pack of 5 -10k) arrived today from China so i'll let you know how i get on! |
