3rd Sep 2022, 2:08 pm | #21 |
Re: Quad 303 mods
More pictures...
3rd Sep 2022, 10:30 pm | #22 |
Re: Quad 303 mods
3rd Sep 2022, 10:32 pm | #23 | |
Re: Quad 303 mods
3rd Sep 2022, 10:37 pm | #24 |
Re: Quad 303 mods
That's a very kind offer, thank you. I do hope that the op goes well and that you will soon be running about again
3rd Sep 2022, 10:39 pm | #25 | |
Re: Quad 303 mods
4th Sep 2022, 8:16 am | #26 |
Re: Quad 303 mods
I will correct one comment i made earlier - the yellow leads are used to connect from the transformer to the rectifier not the caps as i said earlier. Just follow the instructions on the 303 upgrade instructions and you won't go wrong though you may find they send instructions though this would not be their normal format as all appear to be downloads. It is up to you if you solder directly onto the pins or not but i used the crimp connectors as i has some and you can take the boards out if you ever need to more easily. I think the pins are silver plated and the crimps possibly ally but will see in time if there is any reaction between metals.
Shrink wrap if you feel inclined but again i only did this as i had some. I have some more pics to follow. |
4th Sep 2022, 8:21 am | #27 |
Re: Quad 303 mods
More pictures ........
4th Sep 2022, 8:23 am | #28 |
Re: Quad 303 mods
and some more.......
4th Sep 2022, 8:25 am | #29 |
Re: Quad 303 mods
and don't forget to set you bias current when done - again follow the instructions. Allow the amp to warm up a bit but easy enough - again use a small piece of wood to keep the boards away from the chassis....
4th Sep 2022, 10:58 pm | #30 | |
Re: Quad 303 mods
I've been trying to think of a method of extending the terminals of the snap-in type capacitors that could be attached or soldered so as to have a larger area to solder the wires to like the original caps, perhaps there's already a method out there that I've not yet come across. |
5th Sep 2022, 7:33 am | #31 | |
Re: Quad 303 mods
22nd Sep 2022, 1:06 pm | #32 | |
Re: Quad 303 mods
23rd Sep 2022, 7:56 am | #33 |
Re: Quad 303 mods
https://shop.dadaelectronics.eu/prin...re-connectors/
https://shop.dadaelectronics.eu/13mm...108463125.html Dada sell the pins and tags so i would go there - bit of a faff ordering/paying as you know but not too difficult and i think your board will be populated already with the pins looking at the online picture? - so you just need the tags. They may even supply these in the kit too but if not, you can order them there and don't forget the two connectors away from the main side of the amp harness for each board. |
24th Sep 2022, 9:59 pm | #34 | |
Re: Quad 303 mods
26th Sep 2022, 9:30 am | #35 |
Re: Quad 303 mods
I have just found these on ebay https://www.ebay.co.uk/itm/134231976...ee24%7Ciid%3A1 mod delete if not allowed
Dave
Any tool can be used as a hammer but a screwdriver makes the best chisel |
