6th Sep 2022, 9:29 am | #1 |
Farnell FG1 Function Generator.
Diodes went s/c and burnt out the mains tx.
I have repaired the former and rewound with new wire. Now the difficult bit, how to clean off the pitch and varnish from the lams. I have tried petrol, parrafin, white spirit, acetone, and in the ultrasonic cleaner at 70 degees, but none will shift the crud. Has anyone successfully cleaned lams without damaging them? John. |
7th Sep 2022, 5:46 am | #2 |
Re: Farnell FG1 Function Generator.
I used a low heat oven, petrol and elbow grease to good effect in the past. Have also used Nitromorse, luckily had some old formula stuff.
Andy.
10th Sep 2022, 4:50 pm | #3 |
Thanks Andy.
The old memory needs a jog sometimes, I have a can of nitromorse in the cupboard. I soaked the lams in it for 24 hours, brushed them off in water with a tooth brush, soaked them in wd40 for a day, got all the lams back in except for a damaged one when I took them out. Stuck the mains on it, 22 volts spot on. John. |
