Old 29th Dec 2016, 8:40 pm   #221
ms660
ms660's Avatar
Default Re: My first valve radio project - Philips 462A
As per post#219, also check that any components/wires on tag 3 of the valve holder are not touching any components/wires on tag 4. Valve holders can leak between the tags by leaking across the valve holders body, worth having a close look.
Lawrence.
ms660 is offline
Old 29th Dec 2016, 9:02 pm   #222
Station X
Station X's Avatar
Try disconnecting R6 so that the grid floats.
What are the anode and grid voltages then with the valve in?
Graham. Forum Moderator
Station X is online now
Old 29th Dec 2016, 9:05 pm   #223
indigo.girl
Lawrence.
I've had a really good look and I can see no touching wires/components that connect to pin 3 that could possibly be contacting wires/componets connected to pin 4. The top and bottom view of the valve holder looks clear between pin hole 3 and 4 and I've given the top of the holder a clean. There is infinite resistance measured between pin holes 3 and 4.
indigo.girl is offline
Old 29th Dec 2016, 9:18 pm   #224
indigo.girl
Snipped one end of R6 (2.2 Mohms). (remember C19 is still snipped)
Pin 3 = +30V (+V2) and +214V (-V2)
Pin 4 = -400 mV (+V2) and +68mV (-V2)
With the Valve in I get closer to the expected values
Old 29th Dec 2016, 9:19 pm   #225
ms660
ms660's Avatar
"There is infinite resistance measured between pin holes 3 and 4"
That isn't always a valid test for electrical leakage, any breakdown could be happening at a higher voltage than a test meter puts out on ohms range.
That said, if there's still a +ve voltage on tag 4 of the valve holder with the valve removed it should be possible to trace the source of the problem, what I would do next is to disconnect the components from tag 3 in order to isolate that tag then check the voltage on tag 4 again.
Whoops...post crossed.
EDIT: That +ve grid voltage previously measured has almost disappeared since R6 has been disconnected and with the valve removed, a known good C17 should be in circuit, what's the voltage at the junction of R6 and R7? It should be -ve with respect to chassis
Lawrence.
ms660 is offline
Old 29th Dec 2016, 9:40 pm   #226
indigo.girl
Lawrence.
I have reconnected R6 and C19 back into the circuit for this test.
With valve removed and pin 3 snipped = pin 4 is still positive at +6V
(pin3 has a small +18mV measurement rather than 0)
I'll now resnip R6 for your next suggestion
Old 29th Dec 2016, 9:49 pm   #227
ms660
ms660's Avatar
The bias supply from the -ve end of C25 should be -ve. With V2 removed somewhere along it's route to the triodes grid tag it's going +ve, check the bias voltage at all points along its route from the supply.
Lawrence.
ms660 is offline
Old 29th Dec 2016, 10:22 pm   #228
indigo.girl
Lawrence.
Its positive at R6/R7 junction
Test conditions: R6 + C19 + pin3 all reconnected to original positions.
Pin 3 = 19.5V (+V2); 242V (-V2)
Pin 4 = -65mV (+V2); 4.5V (-V2)
Voltage at R6 - R7 junction (wrt chassis) = +9.5V (+V2); +11V (-V2)
Old 29th Dec 2016, 10:27 pm   #229
ms660
ms660's Avatar
Lawrence.
Hang on in....
Voltage on the other end of R7, the end that connects to the junction of R19 and R20 with V2 removed.
Lawrence.
ms660 is offline
Old 29th Dec 2016, 10:43 pm   #230
indigo.girl
Lawrence.
Not completely sure I understand this action. With V2 removed the negative side of C25 is -4.5V. This is connected to the R15 variable resistor (tone control). On the other side of R15 the voltage is -3.5V. This then connects to C21. On the other side of C21 the voltage is +225V. This then connects to V2 triode ANODE (pin 3) rather than the Grid tag (I presume this means control grid pin4). Is this what you wanted me to check Lawrence?
Hold on ... I've seen the path to the grid too...
C25 also goes via R20 to R7 to R6 and then onto the grid tag (pin4). The voltage on the R20 side of R7 is -1.6V. On the other side of R7 it's +8Vs This is where is goes from neg to pos.
Old 29th Dec 2016, 10:57 pm   #231
ms660
ms660's Avatar
Lawrence.
Not completely sure I understand this action. With V2 removed the negative side of C25 is -4.5V. This is connected to the R15 variable resistor. On the other side of R15 the voltage is -3.5V. This then connects to C21. On the other side of C21 the voltage is +225V. This then connects to V2 triode ANODE (pin 3) rather than the Grid tag (I presume this means control grid pin4). Is this what you wanted me to check Lawrence?
That tells us that the grid bias supply at source is being produced as expected polarity wise and that it changes polarity somewhere between its source and the grid side of R7, to be absolutely sure that it's -ve when connected to R7's bottom end as viewed in the schematic measure the voltage at the actual end of R7, that's the bottom end looking at the schematic, in order to get to the bottom of this we have to eliminate all possibilities, It will happen I'm sure.
EDIT: Yes C21 does connect to the triodes anode and not the triodes grid.
Lawrence.
ms660 is offline
Old 29th Dec 2016, 11:08 pm   #232
indigo.girl
Lawrence.
Yes, at every bit of bare wire between R20 and the bottom of R7 the voltage is -1.6V.
Old 29th Dec 2016, 11:22 pm   #233
Station X
Station X's Avatar
Is that with everything connected apart from the top end of R6?
Old 29th Dec 2016, 11:26 pm   #234
ms660
ms660's Avatar
Lawrence.
Ok, can your other test meter measure resistances above 2M ohm? If not I would replace R7 (2.2M) before you go any further, If it's gone very high or open circuit it would leave the grid tag floating, anything that's floating can pick up stray voltages from a high impedance source and sometimes a high impedance digital meter will register them.
Lawrence.
ms660 is offline
Old 29th Dec 2016, 11:28 pm   #235
indigo.girl
No, R6 is connected.
Old 29th Dec 2016, 11:31 pm   #236
indigo.girl
Lawrence.
Just to confirm; you mean R6 here don't you?
And yes my other meter does do higher resistance measurements up to 20 or 2000Mohms. I'll try it now.
Correction: My other meter needs an extra attachment for high resistance measurements - so no I can't measure it. So its possible its gone very high resistance (I presume not completely open circuit else snipping it out would have given no different effect but it did).
I'll have to see what I have knocking around to see if I can replace it tonight....
Old 29th Dec 2016, 11:48 pm   #237
ms660
ms660's Avatar
My apologies, I had annotated the schematic I have with the values of R6 and R7 but I wrote them in the wrong positions
Lawrence.
ms660 is offline
Old 29th Dec 2016, 11:53 pm   #238
MotorBikeLes
If your testmeter is limited to 2Mohm, put a known value in parallel (470K, 1M or why?), take measurement and then calculate correct value for your 2.2Mohm suspect. formula: 1/Rx=(1/R1+1/R2).
Les
MotorBikeLes is offline
Old 30th Dec 2016, 12:01 am   #239
crackle
Keep at it Lawrence and Nicola, its getting quite exciting.
crackle is offline
Old 30th Dec 2016, 12:04 am   #240
ms660
ms660's Avatar
Yeah, luv it, trouble today is we ran out of firewood last night so been cutting and hauling timber from down the woods for a few hours today...My pillow beckons, anyways enough of that.
Lawrence.
ms660 is offline
