Reply
Old 4th Nov 2023, 12:25 am   #1
kellys_eye
Default Mystery test set
Can anyone identify this unit and offer any history or advice on it?
ID:	287346   Click image for larger version
kellys_eye is offline   Reply With Quote
Old 4th Nov 2023, 8:08 am   #2
CambridgeWorks
CambridgeWorks's Avatar
Default Re: Mystery test set
Looks like a modified original of something or home made. Maybe has 2 band rf sig gen, audio osc out, audio monitor for headphones and a multi range dc voltmeter.
A picture of top and bottom of chassis would help.
Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is offline   Reply With Quote
Old 4th Nov 2023, 9:15 am   #3
Craig Sawyers
Craig Sawyers's Avatar
Looks like white Letraset, not well aligned with the controls. Which suggests homebrew.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is online now   Reply With Quote
Old 4th Nov 2023, 9:21 am   #4
Radio Wrangler
Radio Wrangler's Avatar
Belling-Lee connectors suggest 1950s or 60s
Radio Wrangler is online now   Reply With Quote
Old 4th Nov 2023, 4:05 pm   #5
factory
Homemade from magazine designs of the 1960s? Anything inside to give clues?
factory is online now   Reply With Quote
Old 5th Nov 2023, 1:31 am   #6
kellys_eye
Top and bottom. I thought homebrew too but starting to think it may have been made semi-pro by a 'name' as a one off. The construction standard is rather impressive - letraset notwithstandiing!
ID:	287373   Click image for larger version
Old 5th Nov 2023, 9:09 am   #7
stuarth
It looks like 3 circuits.
The left hand bit looks like a 2 band signal generator.
The right hand bit looks like a valve voltmeter (coax input with one side connected to chassis rather than floating, and a set zero control on the front - and there’s a valve in there!)
The middle bit looks like 2 valves and an output transformer, which would match the “signal tracer” label on the front.
It is beautifully made. Somewhere with good metal bashing facilities, but no panel lettering facilities.
Stuart
stuarth is offline   Reply With Quote
Old 5th Nov 2023, 9:58 am   #8
CambridgeWorks
I would think home made. Those red resistors have paxolin tagstrip at rear and looks like ceramic in middle. Some wiring very neat, some not so and different size. Bit jumbled up around a valve base as well. Also the brown cable just loosely entering at rear, no hole with a grommet. Lastly, where is the psu? That tiny transformer looks like o/p type and who would use a bathtub capacitor (rear corner) when this was made? Probably from the 60s or 70s even from a well stocked junkbox assortment.
Rob
Reply
