29th Nov 2020, 12:16 pm | #1 |
Loud pop when turntable switches off
I've recently restored and Bush SRP31D and very pleased with it's performance but its just developed an annoying fault.
After it's finished playing a record and the arm returns to the cradle the turntable automatically switches off and makes quite a loud popping noise from the speaker. I'm wondering what's causing this and how to sort it out! Thanks
Clive |
29th Nov 2020, 12:19 pm | #2 |
Re: Loud pop when turntable switches off
The cause is likely to be due to the switch contacts arcing. I suggest you add a capacitor of about 10nF across the contacts, or perhaps a suppressor which is usually a C & R in series.
29th Nov 2020, 12:21 pm | #3 |
It needs a "switch click suppressor" - in other words a large value (c 0.1uF 500V) cap wired across the motor switch. They used to be standard on some higher end Garrard turntables.
Edward. |
29th Nov 2020, 7:12 pm | #4 |
Thanks very much for the advice, will add the said capacitor tomorrow and report back.
Clive |
29th Nov 2020, 10:09 pm | #5 |
I think 0.1uF is too big unless it includes a series resistor, thats why I suggested 10nF (0.01uF), make sure its an X rated type, ie 275V AC.
30th Nov 2020, 1:20 am | #6 |
Absolutely agree.
Steve.
30th Nov 2020, 9:20 am | #7 |
Just as an observation I note that 0.1ufd are used in some Bush Radios, without a series resistor.
John |
30th Nov 2020, 9:53 am | #8 |
I have found purpose made snubbers very helpful for this.
Paul |
30th Nov 2020, 10:02 am | #9 |
Reference my post #7, I was thinking of mains suppression so please ignore my observations, must put brain into gear
John |
30th Nov 2020, 1:05 pm | #10 | |
I've checked my "stock" and found I have just 1 uF and .22 uF X rated (275V) capacitors, I don't know how critical this is, will either of those do or should I order a 0.01 uF as recommended?
Clive |
30th Nov 2020, 3:06 pm | #11 |
Much too high. Best order a .01 (10nF) 275V.
30th Nov 2020, 6:36 pm | #12 |
A 0.22uF with 100 ohms in series will be fine.
30th Nov 2020, 9:08 pm | #13 |
Best thing to do is just try it. Sometimes theory and practice don't always go hand in hand!!
4th Dec 2020, 1:02 pm | #14 |
The first couple of posts suggested the cap is wired across the motor switch contacts. I assume this is in parallel.
Anyway, I've received the correct rated capacitor and wired it in as this and it's sorted out the problem, hardly any noise to worry about now, many thanks for the help
Clive |
4th Dec 2020, 1:29 pm | #15 |
so what type and value cap did you use.
4th Dec 2020, 3:06 pm | #16 |
0.01uF, X rated type, 300V
Clive |
4th Dec 2020, 5:06 pm | #17 |
Question to the boffins - if you have a double pole switch where live cannot be determined (European plugs) then two capacitors should be fitted? Or is it just one for the whole circuit?
4th Dec 2020, 6:30 pm | #18 |
One across each switch, the "liveness" doesn't matter, one will switch first. Which one one never knows. (The first time I have done "one one")
