23rd Dec 2018, 10:23 pm | #1 |
CR123 rather than 2xAA cells
To use a CR123 instead of two AA cells would I need to have a diode to 'lose' the difference in voltage?
If so. Which one? |
23rd Dec 2018, 10:32 pm | #2 |
Re: CR123 rather than 2xAA cells
The nominal voltage of a CR123A battery is 3 volts. Much like 2 x AA alkaline cells in series. Why do you need a diode at all?
Richard |
23rd Dec 2018, 11:38 pm | #3 |
I thought they were 3.7V or a different make-up of CR123 made the extra voltage when fresh.
It is purely a space consideration choosing this battery rather than a pair of AA's. How many mAh is average vs the pair of AA for the same chemical make-up? |
24th Dec 2018, 12:22 am | #4 |
Primary CR123 Lithium batteries are 3 volt, rechargeable CR123 Li-ion are 3.6 volts.
Information from Wikipedia.
Frank |
24th Dec 2018, 7:13 am | #5 |
I was looking at the re-chargeable CR123.
I figured i'd need to lose 0.6V, assuming the voltage remained constant until the charge was exhausted. |
24th Dec 2018, 8:25 am | #6 |
Almost all things powered by batteries I've come across are tolerant of over voltage. I've powered 9v radio's off car batteries for instance without harm. 0.6v in the scheme of things is nowt.
Andy.
24th Dec 2018, 9:19 am | #7 |
While pondering this query I came across this post about problems with this specific battery format, which you might want to consider:
https://www.knivesandtools.co.uk/en/...ry-rcr123a.htm |
6th Jan 2019, 8:48 am | #8 |
The little pocket radio kits I am making mean I am not drawing more than 10mA & the CR123 is for these. A re-chargeable CR123 would be OK here?
I know just how damn hot these cells can get if inadvertently shorted |
10th Jan 2019, 4:04 pm | #9 |
I'm always happy to be proved wrong but 0.6v in relation to a supply voltage of 3v is 20% The appliances in my house run on 230v but I don't think I'd be willing to test that theory by winding them up to 276v on the variac... Cheers
Lee |
10th Jan 2019, 5:08 pm | #10 |
If I am not mistaken, the voltage of a fully-charged CR123 lithium battery will be 4.2 V, similar to a 18650 battery. That's quite a bit over the 3V or more expected from a fresh pair of AA alkaline cells. Personally I would be reluctant to use this long-term but I don't think it would cause any immediate damage as most 3V radio components would have higher voltage ratings. Some unregulated radio and Walkman AC adaptors often provide an output well over their specified voltage e.g. 9V instead of the rated 6V.
If using a CR123 is a must, a 3 V zener diode circuit might be the best solution. AFAIK there are no ICs that would regulate down to 3V without requiring a much higher input voltage. I am not fan of IC based voltage regulators in radio circuits as they can cause RF noise. One important point is to make sure to add a fuse to the power supply circuit if using a rechargeable battery. Last edited by Jolly 7; 10th Jan 2019 at 5:17 pm. |
10th Jan 2019, 5:15 pm | #11 | |
Example - the TDA3663 which is used in laptops etc. to provide the 3.3V rail. |
10th Jan 2019, 5:20 pm | #12 |
The TDA3663 is SMD only if I am not mistaken ?
10th Jan 2019, 5:50 pm | #13 |
SO-8, yes. I generally solder these sorts of chips to something like this:
http://www.hobbytronics.co.uk/soic-dip-breakout-8-ht so I don't lose the SMD chips if I sneeze. ((my most-recent bit of 'gash' electronics involved a NE602/SA602 type SMD chip as a mixer)). |
10th Jan 2019, 6:23 pm | #14 |
It's the flu season after all
In your experience have you found RF noise being generated from the TDA3663 ? I once tried to use a 78LO5 in a radio circuit but was forced to remove it because of the interference from it. |
10th Jan 2019, 6:41 pm | #15 |
I've not had noise issues with the likes of the 3663 - or 78xx-series for that matter. I've used 78xx etc. to regulate the supply to VFOs/post-VFO buffer-amps and found the result to be a lot smoother than the classic resistor-Zener regulators.
But there again - anything with gain can oscillate if you tempt it correctly! |
