Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 21st Nov 2023, 2:58 pm   #1
Pilot Mariner
Pilot Mariner's Avatar
Location: Burntwood, Staffordshire, UK or Kabaty in Warsaw Poland.
Default Connection not secure message
Every time I access the site I get this message.
I usually just press continue to site regardless without any problems.
Pilot Mariner is offline   Reply With Quote
Old 21st Nov 2023, 3:22 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Connection not secure message
Check your computer's time and date are set correctly.
What URL are you using to access the forum? Please copy it from the address bar and post it here.
Do you get the error if you click on this link? https://www.vintage-radio.net/forum/
paulsherwin is online now   Reply With Quote
Old 21st Nov 2023, 3:46 pm   #3
Pilot Mariner
Hi Paul
Time and date are correct
This is the URL https://www.vintage-radio.net/forum/
I don't get the error using your link
Just to add that occasionally I don't get the error message, but most time I do.
This is my works PC.
Mark
Old 21st Nov 2023, 4:30 pm   #4
paulsherwin
You probably have a bookmark saved which is using the old unencrypted URL, http://www.vintage-radio.net/forum/. This should automatically redirect to https://www.vintage-radio.net/forum/ but in some cases this will trigger the security warning you're seeing.
Edit your bookmark, changing 'http' to 'https', and the problem should go away.
Old 21st Nov 2023, 6:56 pm   #5
SiriusHardware
Pilot's bookmark already is set for the https:... version? (Post #3).
SiriusHardware is online now   Reply With Quote
Old 21st Nov 2023, 7:07 pm   #6
paulsherwin
No, that's the URL that he's seeing after accessing the forum and the http->https redirect has taken place. If he checks his bookmark he'll see it's incorrect.
Old 22nd Nov 2023, 12:39 pm   #7
Pilot Mariner
All is well now thanks.
