20th Mar 2019, 11:03 pm | #1 |
HP 1222A oscilloscope vertical input FET transistors
Good evening,
I am currently playing with an HP 1222A oscilloscope with a defective channel A input and channel B not working correctly. Having a poke about with a working oscilloscope and a signal generator it appears to be the vertical input dual FET transistors which are at fault. These are the first active semiconductor components from the BNC sockets and it looks like they could have succumbed to a high voltage being applied on the channel A+B BNC sockets. These devices are dual N channel JFET's. Each can holds 2 separate FET devices. One device for the A or B channel input amplifier and the other device used as a voltage source for the next stage in the amplifier. To prevent cross coupling, one device is used per channel. The part numbers show that they are pretty much unobtainable as you would have guessed!! Could 2 standard N channel JFET's be used to replace the oddball dual FET can?. What types could be used. The vertical bandwidth of this oscilloscope is 15MHz Many thanks, Christopher Capener
20th Mar 2019, 11:14 pm | #2 |
Re: HP 1222A oscilloscope vertical input FET transistors
The JFET is on the right hand side of the A2A2 amplifier. The other device in the dual JFET package is used later on in the amplifier as a voltage source.
You get a healthy looking signal on the gate with a signal generator connected to A channel but on the source output resistor there is just DC. B channel has a signal on the source though it is fairly small and believe this JFET has been damaged as well. Christopher Capener
Interests in the collection and restoration of Tefifon players and 405 line television Last edited by high_vacuum_house; 20th Mar 2019 at 11:24 pm. |
21st Mar 2019, 6:54 am | #3 |
"Could 2 standard N channel JFET's be used to replace the oddball dual FET can?" AFAIK they need to be matched and bonded thermally Chris, also AFAIK you can still get dual tranny's, probably SMD package, wether within the same spec as those I've no idea, do a search on mouser/digikey.
Andy. PS - https://www.digikey.co.uk/products/e...?k=dual%20fets
21st Mar 2019, 10:17 am | #4 |
It's certainly worth experimenting. I had a similar problem with a special Tektronix dual FET in a 7A22 vertical plugin (the one with the legendary 10 microvolts/cm differential sensitivity). It was a bit leaky, which meant that the trace wandered off the screen at higher gain settings.
I bought a load (about 20) of run-of-the-mill J113 FETs and made a simple circuit to measure the gate voltage at the drain current at which the circuit operated. I found two that were acceptably close and put them in the plugin. It works fine, and the performance is now indistinguishable from another 7A22 with the original dual FET in. The Tek plugin has a little plastic hat which fits over the FET socket, presumably to keep draughts away from it. The thermal connection of two single FETs will be nowhere near as good as a dual one, of course, but gluing their packages together would probably help a bit. Chris
21st Mar 2019, 1:29 pm | #5 |
A U440 dual-FET might be suitable. Data readily available on the www. This item is available from various, incl. Farnell.
Al. |
21st Mar 2019, 1:53 pm | #6 |
I second Chris' suggestion. I used 2 x MPF102 to replace the input stage of the external trigger input on a Tektronix 7B80 timebase plugin with no problems. A quick check shows that the trigger sensitivity exceeds the spec by a large margin, at least to 250MHz which is far as I can easily test it. One reason for choosing the MPF102 is that they mount flat face to flat face in the Tek six pin socket, you could make a small brass clip to hold them together.
Regards, Roger |
21st Mar 2019, 2:29 pm | #7 |
Do you have the HP part number or OEM part number. I've got about 30 dual JFETs here. Might have a direct replacement!
21st Mar 2019, 2:41 pm | #8 |
Something like his (with leads soldered on!) should work:
On Semiconductor CPH6904 John |
21st Mar 2019, 4:07 pm | #9 |
This was known in HP as 'The plastic scope' designed to try and capture some of the educational market and service bench market for ultra cheap instruments (well, relative to normal HP prices )
There were no fancy parts in it, things already set up were chosen. CRT accelerating potential is rather low, the trace dim, and the spot could be driven off the screen by rubbing the plastic implosion guard. THere was one kicking around in our lab. Never used for work, but occasionally signed out by someone wanting one for a few days to fix their TV. It did that OK, but was less good than a telequipment dual channel job. Probably a pair of 2N5245 or something of that ilk with a bit of selection and a metal temperature link between them ought to do. David
21st Mar 2019, 8:30 pm | #10 |
Good evening,
Many thanks for your replies. This oscilloscope is certainly very basic on the front panel controls side and also on the inside and looks as if it was intended for educational/low performance work use. I noticed it has a low EHT with all of the connections made to the CRT base, their being no anode stud or deflection plate pins in the CRT bulb envelope. This oscilloscope was got at Harpenden for £5 and was in a rather poor state. I have quite a few massively better/ performance oscilloscopes than this one. I just wanted the challenge of seeing if I can get it going!! I might try a pair of MPF102 JFET devices or a 2N5245 device to see if I can get any results as I can get these on Ebay fairly cheaply and these devices will be working within their maximum ratings. The CPH6904 dual FET has an internal common connection and therefore probably not desirable in this design. Christopher Capener
21st Mar 2019, 9:43 pm | #11 |
I'd have bought it for a fiver.
Coincidentally I came across this earlier while looking for something completely different.... https://www.hpl.hp.com/hpjournal/pdf...Fs/1974-02.pdf |
22nd Mar 2019, 9:04 am | #12 | |
You might be able to reverse D & S (I think that's the case with JFET'S?) John |
28th Mar 2019, 12:55 pm | #13 | |
greetings Martin
www.wellenkino.de Vintage Scope restorations |
