Old 12th Jul 2019, 8:01 am   #1
wimderotte
Default CT160 scale plate
Dear reader,
I need two scale plates for an AVO CT160
Please help me to find this plates
Best Regards
Wim
wimderotte is offline
Old 12th Jul 2019, 9:04 am   #2
Ed_Dinning
Default Re: CT160 scale plate
Hi Wim, I think there are some programmes available ("Meter" for example) that will allow you to create/ replicate your own meter scale on a PC and then print out onto a suitable media.
Ed
Ed_Dinning is offline
Old 12th Jul 2019, 9:54 am   #3
llama
llama's Avatar
Or just take your image to a photo-booth in a supermarket.
Graham
llama is offline
Old 12th Jul 2019, 10:17 am   #4
David G4EBT
David G4EBT's Avatar
Some time ago there was a major article on Avo Valve Tester meters and dials by Gary Tempest, in the BVWS Bulletin - I can recall which issue - maybe someone else might know? It had very clear drawings of the dials, I think on the back page of the Bulletin, which could be scanned and used to either create waterslide decals, or perhaps more easily, to print onto photo paper (gloss or satin say), and fixed to a dial plate. I've done that often on smaller meters that I've adapted for homebrew projects. The third pic is of a scale for a homebrew ESR meter fitted to the dial plate of a 50uA meter.
Alternatively, the image by Wim in post #1 could be cleaned up in Photoshop and a dial decal/phot be created from that. Admittedly it would be a bit tedious, but would provide a solution if Wim's quest for dials isn't successful. I've spent a few minutes cleaning up the background a bit to illustrate that with time, the dial could be 'cloned' using Photoshop. I've shown it below alongside Wim's picture. The scale and lettering would of course need to be cleaned up.
As we know, Avo valve testers command high prices and become a hobby in their own right. The meter is such a focal point that a scale that looks less than perfect will detract from the appearance, look like a bodge and might suggest other unseen bodges 'under the bonnet'.
Best wishes in your quest to find dials Wim.
Name:	Avo CT160 Dial.jpg
ID:	186516   Click image for larger version
Name:	Avo CT160 Dial cleaned up a bit.jpg
ID:	186517   Click image for larger version
Name:	ESR meter Dial newer.jpg
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 12th Jul 2019, 11:03 am   #5
chriswood1900
You might find this thread of use:-
https://www.vintage-radio.net/forum/...ad.php?t=46825
also I had this saved on my PC but I can't remember where it came from so apologies to whoever posted it.
Chris
chriswood1900 is offline
Old 12th Jul 2019, 12:18 pm   #6
David Simpson
I too have some scanned copies. So you've several choices. Best to choose one you like, then PM one of us with your email address, so that we can send you a better definition copy. Then print onto some photo glossy quality card.
Regards, David
Name:	CT160 Scale Plate.jpg
David Simpson is offline
