20th Sep 2015, 1:30 pm | #1 |
Grundig video 2x4 smoke help
Hi guys, I picked up a V2000 player a Grundig 2x4, fixed it, and was watching a tape on it when it started spewing blue smoke from the power supply board. I have had the board out but cant figure out where the smoke was coming from. there is a strong smell around a large component that I do not know what it is. Its a Siemens AZ3-5656, which is a big blue block. I have done most of the caps on the PCB and they're still fine.
Please any advice and help would be super, as I reallly want to get this back up and running Alan This was it playing a few days ago https://youtu.be/QuWkD0lgJRY |
20th Sep 2015, 1:37 pm | #2 |
Re: Grundig video 2x4 smoke help
20th Sep 2015, 1:41 pm | #3 |
Most likely point would be the blue Mains filter capacitors, you would need to remove to discover which has failed, cant quite see from your picture but also look for any Rifa make capacitors, there could be one nest to the large round transistor on the heatsink.
20th Sep 2015, 5:01 pm | #4 |
the blue cap next to the round white toped on is 0.47 @250v can i use any .47 @250 or is it a special cap that has to a dipped one. and probably a stupid question are they still 2 legged + and -. nver worked with large v stuff before
Alan |
20th Sep 2015, 6:56 pm | #5 |
If that is the blue cap on the extreme left of the pix, it looks like a mains suppressor cap, so it should be X type or X2 type 250v AC, not an ordinary 0.47uf 250v DC cap. That's just a guess as it seems to be next to the mains fuse?
It is still only 2 wires, not polarised and not electrolytic! |
20th Sep 2015, 7:19 pm | #6 |
As a test, unsolder the suspect component and try the machine again.
If it works normally, all you need to do is buy a suitable mains filter cap and fit. Nick. |
21st Sep 2015, 2:14 pm | #7 |
found the fault it was the .22 @ 250 Mains filter capacitor all the side is blown out. i have 2 replacements the said they they where the right ones at maplins one is 0.47 @250 the other one 0.22@250. let me know it they are as there a lot smaller than what came out
Alan |
21st Sep 2015, 2:15 pm | #8 |
21st Sep 2015, 2:30 pm | #9 |
The 224 cap will be ok.
Malc Scott |
21st Sep 2015, 3:35 pm | #10 |
what about the 473k for the 0.47 is that not the correct one? also is there a + lead or are they not polarized?
Alan Last edited by 2ombieboy; 21st Sep 2015 at 3:41 pm. |
21st Sep 2015, 3:47 pm | #11 |
These capacitors are not polarised, they can be fitted either way round.
But 473k is not 0.47uF. It's 10 times smaller (0.047uF = 47nF). A 0.47uF capacitor would be marked 474. You read them a bit like resistors, 2 digits and a multiplier, the value then being given in picofarads (pf). So 473 -> 47*10^3pf = 47nf = 0.047uF. 474 -> 47*10^4pF = 0.47uF |
21st Sep 2015, 8:32 pm | #12 |
Job done, now back up and running. re capped the board and re done a trace or two as they had started to pull away
Any one know the pin out of the AV socket its a 6 pin DIN. need to make a DIN to RCA cable Alan Last edited by AC/HL; 21st Sep 2015 at 11:03 pm. Reason: Images uploaded |
22nd Sep 2015, 7:35 am | #13 |
1: AV Switching voltage input (+12V to switch the set to AV)
2: Composite Video input 3: Ground 4: Audio Left 5: +12V output (for switching purpose)(A Bridge from 1 to 5 switches the set to AV) 6: Audio Right Connect them in this way to the SCART Connector: DIN --> SCART 1 8 2 19 3 4+17+21 4 3 5 - 6 1 Pins viewed from solder side
Stephen _________"It`s only an old telly" ___ Last edited by Freya; 22nd Sep 2015 at 8:05 am. |
23rd Sep 2015, 9:37 am | #14 |
thanks buddy
Alan |
